Results 1 to 11 of 11
Thread: What's up with my formerly well behaved pool?
    Jul 2008
    Seacoast, NH
    252
    We've had our pool for a year now. Once we got the water balanced, we've never had a problem with the Chlorine. We've used the BBB method since the beginning. Some of the other chemicals have bugged me at times, but the Chlorine has always been perfect.
    I check the FC, CC, and pH almost every day. Yesterday I didn't because it was pouring. On Monday I happened to check everything and results were
    FC 3.5
    CC 0
    ph 7.5
    TA 90
    CH 200
    CYA 55
    I have a Taylor 2006 kit.
    I know CYA is a little low, but its been a struggle to get the level up. We've had massive amounts of rain this summer.
    So, today I came home from work and tested the water, fully expecting my standard 3.5 FC and there is NO FC. Like zero. I put 2 scoops of powder in and no pink. I put another one in and just a touch pink. I was so surprised I did the test 3 times. I thought maybe my powder went bad overnight so I used some test strips I have for days I feel lazy. Nothing. BTW, pH was 7.5.
    So, now I'm worried I'm on the verge of an algae bloom. There were a couple of dead of dead frogs in the pool, but that's nothing unusual for us. We haven't had anyone swimming in the pool since Saturday, and then only one adult.
    Other data: I had to add water from our well on Monday because the level was down after a warm spell. Yesterday we had torrential rains. Could either of those cause this issue?
    I just added some shock 'n swim an hour ago and will check the FC in a few minutes. I'll keep adding it until I get the FC up to shock levels and then I'll keep it there until tomorrow and then I'll do an over night test. Does that sound like a plan? I don't have any liquid chlorine around. The only other Chlorine source I have around, besides my SWG, is tablets. I could use those too or instead. I just don't really feel like going out to buy chlorine, but I will if you tell me I need to.
    Thanks for your help.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    May 2009
    Seminole, FL
    71
    Re: What's up with my formerly well behaved pool?
    Wait!! What is shock and clear? Just add chlorine! I see you have a SWG - Is it working?
    ~13000 inground plaster
    150sq Ft Cartridge Filter
    Jul 2008
    Seacoast, NH
    252
    Shock and Swim. It's Calcium Hypochlorite
    1.5 HP Pump
    May 2009
    Seminole, FL
    71
    Quote Originally Posted by Deb04
    Thats probably fine since your CH is pretty low and I don't think it matters much for a vinyl pool. Of course if you follow the BBB method you should only be adding bleach! Which is really all you need.
    Jul 2008
    Seacoast, NH
    252
    Oh, you also asked if my SWG is working. It appears to be. All of the lights are where they should be.
    1.5 HP Pump
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    well technically since you're at 0 you should shock as you know. you could start it tonight and do an overnight loss test tonight to potentially kill 2 birds with one stone. just make sure the swg is off if you choose to do it that way.
    there's nothing wrong with adding calhypo or dichlor or trichlor or whatever as long as you know your other levels and the effect the chemicals will have. it may even be easier for you to raise your cya by using dichlor. bbb stands for proper testing and balancing more than it stands for any certain chemicals.
    you can also use www.thepoolcalculator.com to find how much of whatever product you are using you need to raise it to shock level. you want to get to shock level sooner than later. that site will also tell you how much other products you are adding (i.e. calcium in your case) by using the effects of chemicals section in the bottom of the page.
    Jul 2008
    Seacoast, NH
    252
    Update:
    Last night at 11:00 FC was 22. I turned off the SWG and considered that the start of my overnight test.
    At 11:15 we got a call that my father-in-law had falled down the stairs and had what turned out to be a fatal head injury. So, naturally, my pool isn't even showing up on my list of priorities right now. However, I don't want things to get out of control as we deal with wake, funeral, out of town guests, etc.
    I happened to wake up at 8:30 this morning after very little sleep and thought, "what the heck, I might as well check the pool. I can't sleep anyway." The FC was 18. What do you think re: that drop in FC? At 8:30 the sun had been up about 2 hours. It was overcast.
    Tonight we got home, FC was 14. CC was 0. If I had algae or something, shouldn't there be some CC?
    I'm thinking of just adding a package of shock 'n swim every night until things calm down and I can do a real overnight test. That probably won't be for about a week.
    Advice?
    Thanks.
    1.5 HP Pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I'm so sorry. That is just terrible
    Arizona
    924
    I am so sorry for your loss.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    11,969
    Oh, Re: the cal-hypo, It should keep things in check until you can take the time to deal with it.
    Hang in there....
    Jul 2008
    Seacoast, NH
    252
    Thank you for the condolences and the advice.
    1.5 HP Pump
