Results 1 to 9 of 9
Thread: Burned salt cell
    Burned salt cell
    I have a pool pilot digitl 220 with a sc-48 cell. I have been having trouble all summer keeping my fc level up. I been having to supplement my santizer for a couple of months now. I've added probably close to 14lbs of stabilier/conditioner and still can't keep my fc up. I opened up my cell today to check for scaling (first time since May) and there were brown marks on the inside of the cell wall and a small amount of scailing. this is my second season with the pool and salt system. If anyone can tell me what this is I would really appreciate it. My current readings are
    Fc=.6
    Tc=.6
    Ph=7.7
    Hardness=200ppm
    Alk=123
    CYA=25ppm
    Copper=.1
    Iron=0
    Salt 2900pm
    I have a 20,000 free form Plaster pool. A little over 1.5 years old.
    thanks
    Mike
    Midland TX, 20,000 gal fiberglass, StaRite pump, cartridge filter, 3 returns, BBB second year
    Mar 2009
    Glendora, California
    169
    Re: Burned salt cell
    How are you testing your water? If the CYA test is accurate, then it is too low. I'm sure an expert will chime in about the marks on your cell.
    don't depend on pool store results.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    My test strips are coming out with the same cya level as the two pool stores I've used to test.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Autopilot recommends CYA at 60-80ppm. Running at a lower level consumes the cell life more quickly, but I doubt you'd see the problem you are having.
    Jul 2007
    Brisbane, Australia
    874
    any burning is usually a sign of bad contact (dirty or loose contacts) or cell operating with little water
    if that's really burning and not some metal stains i'd say your water flow was partly blocked so the plates overheated and melted plastic.
    although if this was a permanent problem i would expect your cell to be melted long time ago
    Thanks- Any idea what type of stains they might be and would they be affecting my cell? I have a Rayovac heater which the water goes through before flowing through the cell.
    Jul 2007
    Brisbane, Australia
    874
    iron seems to be the obvious one, but you say there is none in the water
    so might be an old stain
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    If you have an older heater (cast iron headers) the porcelain coating fails, and you start to get rust. Sometimes, even pieces come off and go into the water stream. You may have had a piece wind up in your cell for a while. It rusted away there, and left no evidence of being there. Except for the stain. I dunno. It could happen...
    Factory Warranty Station for:
    May 2009
    Austin, Texas
    77
    I've been having the same problem, and my cell is also coated brown--I can scratch it off with my fingernail near where I can reach. Is this affecting it's ability to produce chlorine? How do I clean it??
    Mike
    25k IG w/ Pebble Sheen +8' diameter spa w/spillway w/ Hayward ProLogic +T-CELL-15 SWCG
    Cartridge Filter and Gas Heater on Hayward Pump SPX3215X20Z1PE (w/ 2.00 HP, 1.10 SF motor)
    +separate waterfall on Hayward Pump SPX3210Z1PE (w/ 1.00 HP, 1.25 SF motor)
