Thread: How do you keep the mender nut on?
    Staten Island NY
    116
    I have a Hayward vacuum and per the instructions I removed one of the sections of hose because it was too long. Upon reconnecting, I follow the instructions on the attached diagram, however I cannot replicate the seal the hose comes out of the factory with and consequently, it separates every other use.
    My next try will be with some sort of lubricant to hopefully get the mender nut on the hose better however my gut tells me it will also make the attachment separate easier.
    Does anyone see any issues with attaching the hose with an automotive hose clamp? I know the chlorine wouldn't be the best for the clamp but inversely, do not know if the clamp will be bad for my water chemistry. Can anyone offer advice on a better method of attaching or alternative method?
    Attached Files Attached Files
    -400 sq ft ingroung Fiji (straight back kidney) ~ 13,500 gallons - Vinyl Liner - 3 to 6 Feet
    -Hayward 1.5 HP Super Pump
    -Hayward Perflex DE Filter EC65A
    -Hayward H 250 Heater
    Mar 2010
    106
    Re: How do you keep the mender nut on?
    Cleaner hose nuts work differently than compression fittings on other types of plumbing/hydraulics. The nut goes onto the fitting first, then slide the hose onto the fitting, then give the nut a couple of twists back onto the hose. Once you get it, it's simple and will hold indefinitely.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by Mayorb
    Good to know. Thanks for that simple explanation.
    Welcome to the forum...
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Are these nuts able to disconnect or one they are on they are stuck?
    built 4/08/2000 16 x32 460 Sq FT Pool 16,000 gallons 3.5 ft 5 ft 3.5 ft sport pool
