Thread: White flakes in pool
    Aug 2009
    Bradenton, Florida
    11
    Hi All, Recent member who is from the Sarasota, Florida area. Have had four pools over the years and have experienced quite a few of the problems that others have described. Right now I am finding a large amount of white flakes coming into the pool. I am figuring that it must have something to do with my SWG (Auto-Pilot), not salt returning, more like calcium. Look forward to your thoughts and suggestions.
    8 K pool, cc 100 filter, Auto-Pilot SWG, 1 HP Whisper-Flo pump, in-ground gunite pool 9 yrs. old,solar heat and Pentair 250K heater.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: White flakes in pool
    Hi can you please post a full set of test results so we can advise better?
    Also a little history of the pool, how old is the pool/equipment.
    You can create a signature for your specs/equip - Go to User Control Panel, then Profile, then Edit Signature.
    Welcome
    Aug 2009
    Bradenton, Florida
    11
    Re: Little white flakes
    Topics Merged by Moderator
    I have asked this same question, but did not get any response. For me, the flakes are quite heavy in the pool and do not reflect the simple answer of the cell simply reversing polarity and cleaning itself. There is a large amount of flakes in the spa and pool which I can net up. They do not go away and the calcium level is within limits. No one has offered a feasible explanation. Please explain your situation. Thanks
    jaybo500, there are a couple of simple tests you can do to narrow down what might be causing the flakes. The first is to put a couple of drops of muriatic acid on a flake and see if it foams up or not. If you want to explore this more, you should start your own topic and ask about it there.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by jaybo500
    I have asked that question previously, however I got no response.
    Hi jaybo500 and welcome to the forum
    The response you received was to ask you to post a full set of test results.
    This request is in the first article in Pool School under "Read This Before You Post".
    If you will provide this info, you will get good advice and ideas.
    You're done SLAMing when:
