Thread: Any alternative solar covers out there?
    I'm tired of replacing our blue plastic solar cover every season or two. Part of it is the hard water in our area... the bubbles on the underside just start falling off. I can tell it's time to replace because every time I take the cover off, there are 10 - 15 new blue bubbles left in the water. Is there a better method out there? I've tried the chemical option, and it didn't seem to work very well. I've seen the solar rings, but not sure those will be much better. Is there something that's not made of plastic that will last longer than a season or two?
    Thanks!
    25000 G, Kidney Shaped, In Ground, Cement Pebbled Finish, Sand Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Any alternative solar covers out there?
    Make sure you are buying a good quality cover and keeping it covered or out of the sunlight when it's off the pool, and don't put it on the pool with the chlorine level high. I don't believe hard water would damage a cover, at least not that quickly. I like the 12 mil covers as a compromise between durability and ease of installation/removal. Anything after the third season is a bonus, IMO.
