Results 1 to 13 of 13
Thread: wall mount skimmer on intex pool
    did a little research on this website and ended up installing a new filter system and added a wall mount skimmer.
    The one that came with the pool that hangs over the wall just gets in the way and is ugly.
    I thought up the mount to go under it and made it out of 2x6 Pt wood. It all worked out great check out the pics and tell me what you think.
    P.S. pools a little dark just starting to try out BBB maintenance plan hope it works.
    15x4 intex starter pool
    Hayward 1hp pump and filter system
    wall mount skimmer
    Re: wall mount skimmer on intex pool
    last two picture working awesome top of pool super clean now.
    wall mount skimmer
    Jul 2009
    Houston, Tx
    19
    I like it! Nice job, but if you had made the support a little larger it could have held the beer cooler.
    Intex 22 x 52 Ultra frame, 10,400 gals
    Intex 2600 gl/hr sand filter
    i'm going to use the other opening that was the original returnn for a second jet just have to get a Y and redo the plumbimg. will post pics when that is finished. If i drank I think that would be a good idea.
    wall mount skimmer
    LOL LOL i started something here didnt i
    Nice job fella
    Gazz
    15 x 36 Intex AGP
    External skimmer
    Mega sand filter
    1/3 HP pump
    http://s286.photobucket.com/albums/ll82/GazzMan9/
    Quote Originally Posted by gd5015
    When we had our intex, hubby made a "beer holder" out of PVC and some kind of plastic peg board. Worked well for years
    18 X 54 Round-Wilbar-Sharkline Above Ground Tahitian
    Stainless steel access panel/ 1.5 hp pump
    Self Installed 6/09
    Crushed by Irene, and a 50ft oak 8/28/11
    Re installing 4/12 and up and running
    When we had the Intex, I never used the skimmer because, like you said it was a pain in the butt and I was afraid if I was not attentive enough, the water could get low and burn up the filter.
    Very, very clever!
    Christine
    Self Installed 6/09
    Feb 2010
    Blessing, Tx (South of Houston)
    82
    Id suggest using the old suction line to still be a suction line, but use a valve to cut the flow down. you will get sombody (ive added a skimmer to mine also, and this WILL happen) go take a look, stick to it, and all the water drains out of the lines FAST, if you keep the old line and just have restricted flow at least you will keep some water in the pump.
    Intex 18' AGP - Intex SWG - 19 inch Sand Dollar Sand Filter - 1HP Pentair Dynamo Pump - 4X20 Solar Panel - Goldline Solar Controller.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    looks good...to get better skimmer action, you want your water level 2/3 of the way up the skimmer
    I would like to put a skimmer on mine as well. I have the 24 x 52 and how would i connect the hose from the Wall skimmer to the inlet valve that is lower? I hope that is not confusing.. lol
    thanks so much
    brandy
    17100 Gallon AGP, Sta-Rite 150sq ft ModMedia Filter, Sta-Rite 1.5 hp Pump
    You didn't have any problems with the liner ripping? I have wanted to put a wall skimmer on mine for a while but I was scared that once I cut the opening in the side of the pool that water would be too much pressure and cause the liner to rip. Did you have to do anything extra to the liner to make sure that it didn't rip? I have the 24 x 52.
    Thanks!
    Laura
    15,500 gal, plaster, Magnetec E-Plus 1.5 HP pump, Hayward Pro-Grid DE Filter
    Pool Pilot DG-220 SWG with SC-60 cell (installed 2006)
    Pentair Letro Legend II pool cleaner with 1.0 HP Emerson pump
    TF-100 Test Kit
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Quote Originally Posted by Dale.s
    Dale,
    How about some pics?
    We all love pics!
    Thanks
    Mike
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    here some pics of my project, ill post some more later of phase 2 lol
    http://i286.photobucket.com/albums/ll82 ... 120184.jpg
    15 x 36 Intex AGP
    External skimmer
    Mega sand filter
    1/3 HP pump
