Thread: Proper CYA technique
    The Taylor website says mix for 30 seconds and then poor into comparator. Another CYA instruction I have on my Pool Solutions PS232 Kit from Ben says mix and wait 30 seconds then poor into comparator. I have tried it both ways and it does make a difference.
    What is the offical way to do this?
    Terry
    25k gal painted concrete, 1hp Pentair Wisperflo pump, Pentair Triton II TR100 sand filter, Stingl Safety vacume relief system. Pool Solutions PS232 FAS/DPD test kit.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Proper CYA technique
    Add CYA reagent to pool sample, Mix, wait 30 seconds, Mix again, then pour into the view tube.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    what are your numbers doing it each way?
    Guest
    I mix it for 30 seconds of shaking, let it sit for about 2-3 minutes in case the temp is low and the reaction is slow because of this, give it another shake and then dispense in the view tube.
    A little higher reading if I mixed for 30 seconds and then poured into tube without waitng.
    Terry
