Thread: Hi from the UK
    Aug 2009
    Hi from the UK
    Hi, I'm new to the forum, just thought I would introduce myself.
    I started my own swimming pool maintenance business last year, and so far it's going really well. I've worked with pools for almost 6 years now in one way or another (started off as a lifeguard!) and thought I would take a chance and go out on my own.
    Every so often I come across a problem that I havent seen before, so it would be good to pick the brains of other forum members, and hopefully I'll be able to help out too.
    Mar 2007
    Coastalish 'down easter'
    Re: Hi from the UK
    Dave, welcome to TFP!!
    Always good to see well intentioned industry dudes here!
    Do some reading at Pool School and poke around the threads for the stuff you usually encounter - you never know when some old pool dude, or experienced owner, may have posted an esier/ more economical way of doing things
    There's getting to be a big, knowledgeable and helpful group of industry guys here - we try to help each other with the problems we encounter and bounce ideas off each other for both our benefit and that of the pool owners here
    It's also nice to have another international member here
    Luv& Luk
    Butterfly's Avatar
    South Carolina
    Re: Hi from the UK
    Hi Dave,
    Welcome to the forum
    You're done SLAMing when:
