Results 1 to 8 of 8
Thread: 1 hp Wisperflow pump - hair in the impeller
    Everytime I clean the strainer basket on the 1 hp Wisperflow I find hair in the impeller. Its hard to get to, but if I stick my fingers into the inlet of the impeller I can drag a glob or two out. It took a while when the pump was new to figure out why the flow had dropped off. Now if I see that pump basket is relatively free of debris but the flow is down I know there is hair that has gone by the basket.
    Does anyone else have the problem. Does anyone have a good solution.
    Terry
    25k gal painted concrete, 1hp Pentair Wisperflo pump, Pentair Triton II TR100 sand filter, Stingl Safety vacume relief system. Pool Solutions PS232 FAS/DPD test kit.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: 1 hp Wisperflow pump - hair in the impeller
    You could use a skimmer sock. But if you have main drains, I don't know what to do about them.
    I also read somewhere if you have people with long hair in the pool, have them band it in a pony tail up high and again down lower. I have short hair so I'm not too familiar with any of that
    One of the experts will be along soon.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Or convince your long haired swimmer that a swim cap can protect their hair from chlorine.
    I think the new ones are not as terrible to get on as the old ones, but I am really guessing.
    The pool is in an RV park so the problem is we don't have the same people swimming everyday. I was hoping to find a better basket or something.
    I'm wondering if I would put a couple of nylon shower scrubbies in the basket if they would catch the hair?
    Terry
    Jul 2007
    Suwanee, GA
    528
    I have the same problem. My wife hair and the hair of my guests with long hair all find their way to my pump. First I'll notice a drop in pressure, beneath my clean filter mark, then if there is a lot of hair in there the pump will sound a bit different. I don't normally use skimmer socks, because of the hassle, but I started using them again to address the hair issue, they catch a small percentage of the hair, the majority goes in the main drain. I have no other option than to cram by hand in there once a week or so and try to get out what I can. I can only reach the impeller with a single finger, but can manage to get out all that I can feel.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,694
    Remember the old days when they wouldn't let you in the pool with long hair without a cap?
    Factory Warranty Station for:
    Oh yes back in the 60's ?? I remember it well. I was visiting parents in Florida a few years ago at a retirement condo. All the old ladies in the pool wore bathing/shower caps. Father-in-law called them Q-tips. All you could see were these white dots bobbing up and down in the pool!
    Terry
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,694
    Quote Originally Posted by notvaporlocked
    Terry
    That cracks me up...
