Thread: Cutting solar covers in half
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    I just got back from vaca and the pool held up great with my cover on. I plan on removing it tomorrow sometime and remembered some people say they are easier to handle if you cut them in half. When you use the cover like that does this effect the spinning while the pump is running??
    18ft. Arcadia Round AGP - 19" Sand Filter, 1 hp pump
    Foam cove/ Gorilla Pad/ Wedding cake steps
    Sta Rite Lil' Shark cleaner and Aquabot Pool Rover cleaner - Aqua-Luminator light and return flow w/fountain attachment
    Added Borates 5/19/09 Taylor K-1005 and Taylor FAS-DPD Chlorine Tests
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Cutting solar covers in half
    If you point the return eyeball slightly downward it should help prevent it from moving out of position.
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Thanks, I didn't have any problem with it moving out of position this time, I was just not sure if I cut it in half if it would still spin or if you have to hook the 2 pieces together first.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    I actually cut mine into fourths...It makes it easier to put in and out by myself...My wife can hand it in to me and then I spread it out. I can then take it out easier then if I have a whole cover or a half a cover...I have a pool fence around the entire pool, I have one section open by the filter and that is where I take it out from.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
