Results 1 to 7 of 7
Thread: Which DE filter!!!
    Jul 2009
    New Jersey
    29
    Which DE filter!!!
    Hi folks,
    I am torn between a Hayward EC75 and a Pentair Nautilus NS36. Any ideas?? Help.
    22.000 Inground Vinyl-2 years old
    Hayward EC75 DE Filter
    1 1/2 Superpump
    CL200 Chlorinator
    Mar 2009
    Glendora, California
    169
    Re: Which DE filter!!!
    Well it comes down to your personal preference. I bought the grid filter since I just couldn't get myself to buy into the "bump technology". If you get the Nautilus, spend a little more and get the 48. That will extend your cleaning cycles.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    Jul 2009
    New Jersey
    29
    I ordered a Hayward EC75.......WOOHOO
    1 1/2 Superpump
    CL200 Chlorinator
    Apr 2008
    San Carlos Mexico
    45
    Take a look at the Pentair Quad I have used them on two pools and like the cartridge ease. They are much easier to clean over the fin style de filters.
    30,000 gal Pebble Tec, Intellifo 4X160, Pentair 80 DE Quad, Pool Pilot SWG, Easy Touch Controls
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by skippr1249
    I've really had my heart set on the Pentair Quad 80. When I was at the pool store the other day the manager said I didn't want that one because the cartridges are so expensive to replace. He then showed me a Hayward 2060, including multiport valve, display of a whole pumping station but not actually running, that was a floor model that he would knock quite a bit off the price. He did ask about my pump, 1.5 uprated by 1.5, so basically it will handle a much larger filter than I have (and the solar I want to put in next summer). He was shocked that I hadn't had problems at my pumping station, pipes, etc., (my filter grids usually last about 3 years) with my 36 sq ft SS DE Filter and asked why I had such a big pump. I told him that was what came with the house/pool (23 yrs ago) and when I had to replace it, I think only once, they just put in the same size pump. The pump is really, really quiet, right under where we sit on the deck and you can't even hear it. The Trex decking probably helps to deaden any sound too. BTW... there are two suction lines, 1.5" combine via 3-way valve, enter pump via 1.5" pipe, then upped to 2" pipe coming out of pump to filter, and one 1.5" going to returns that is downsized from a 2" pipe coming out of filter. Booster pump comes off of return pipe soon after filter, via hose, then leaves pump via hose attached to 3-way valve going to 1.5" dedicated cleaner return line. So I'm not worried about pump being able to handle the big filter. I have excellent return pressure, and just installed my second PoolSkim. With other two returns put restricters in the eyeballs and each PoolSkim has excellent venturi action and Polaris moves some without the booster pump turned on. I never let the pressure rise more than 10 psi.
    Anyway, since you have experience with the Quad, would I be making a mistake not getting it? I have boo-koos of fine silt blown into the pool and dragged in by the dogs. Until this week, with water being much colder and puppies not getting in and out of it so much, I was having to backwash my 36 sq ft twice, and sometimes three times a week. Before we got these puppies I could go a week or more between backwashings. The Quad 80, also, doesn't need as much vertical clearance as the Hayward appears to need. I'm going to have to dig out a hole anyway anyway, a little down the hill from the original pad to get enough vertical clearance for just about any larger filter I get, because filter is under the deck. My current filter doesn't have enough head room so I have to unhook it from system and carry it out from beneath the deck to clean grids. I really like the idea of the ease of taking the top off the Quad to rinse out the media and hose off the cartridges.
    Although the Quad and new multi-valve will cost me more I'm willing to spend that in order to lessen some of the hassles of my current system. Also, I'll be keeping the pool open for winter and I can't trust that the current filter will make it through the whole night, when we have freezing temps, i.e., too much pressure rise during night from blown in debris, sand, silt. (It's really windy out here.) So I need to get the new filter in really soon. Besides that I don't want to be doing so much backwashing during the winter.
    Would appreciate some advice on this from anyone. I need to make a fast decision as it is not too late to cancel the order I have made for the Quad 80 and get the flex pipe and fittings ordered in next few days. I'm not moving the whole pumping station but just the filter about 5' down from pumping station.
    Thanks, gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    South Central NJ
    3,192
    Quad DE filters are made or the same stuff regular DE grids are mad of. The cartridges should last just as long if not longer. They are also one heck of lot easier to clean and are less restrictive. Great filter. Great idea.
    Scott
    PoolGuyNJ
    Owner of - PoolGuyNJ LLC
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by PoolGuyNJ
    Scott
    PoolGuyNJ
    Thanks Scott. Quad it is.
