Results 1 to 10 of 10
Thread: (PICTURE ADDED) AQUA TROL HP Percentage Setting Going Way UP
    I have a Aquat trol on a 14000 above ground. I run the pump (on low) 12 hours a day 8 am to 8 pm. I had been running the percentage setting on 35% until a couple of weeks ago with no problem. (holding whatever FC level I was at)
    I now am having to run it on 60 to 70 percent to keep the same 4-5 FC. I ran it at 50% through the night last night and only got a .5 increase. I am not showing any CC.
    The only change I can point to is a bad thunder storm that filled the pool with crape mytle debris. Some got through my filter and actually clogged the cell. While I had it off I went adead and acid cleaned it. Any ideas on what has changed.
    The unit is new this year.
    Salt 3000 - 3400
    PH 7.5
    TA 120
    CH 310
    CYA 100 (drained and refilled some yesterday to lower, will check tomorrow)
    24' Above Ground
    Aqua-Trol SWG
    1 1/2 HP 2 speed pump
    Cartridge Filter
    Re: AQUA TROL HP Percentage Setting Going Way UP
    Most likely you have a low level algae problem. The SWG is holding the algae in check, so it isn't obviously visible, but isn't enough to kill it off completely. You can confirm this by doing an overnight FC loss test. If you lose chlorine overnight, you have algae and need to shock the pool.
    I will do that tonight.
    Thanks
    24' Above Ground
    Aqua-Trol SWG
    Cartridge Filter
    Re: (PICTURE ADDED) AQUA TROL HP Percentage Setting Going Way UP
    While I am waiting to do the loss test I have been reading other post. I read a few about Mustard algae and wonder it I have it. I have been having to vacuum every couple of days for what I thought was sand. But it looks like some descriptions of algae from other post.
    Looks like sand but you can not pick it up no matter how slow you try. It just turns to dust.
    No grains of sand to pick up.
    I did take the filter out this afternoon and clean it in TSP. It did have a greenish tint.
    Here are a few pics I tool with a underwater camera.
    24' Above Ground
    Aqua-Trol SWG
    Cartridge Filter
    Is it OK to run the pump during the overnight loss test? Or does it matter. I have the SWG off.
    24' Above Ground
    Aqua-Trol SWG
    Cartridge Filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    yes, run the pump. Doesn't look like live algae.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Have you put a clarifier in recently? That looks like what a clarifier does. It clumps, (technical term) the little pieces into big pieces so you can vac them up.
    Factory Warranty Station for:
    Ran Loss Test this morning. (Using TF-100 Kit)
    5.0 FC last night
    5.0 FC this morning
    I am going to set my generator at 50% today and see where I am tonight.
    24' Above Ground
    Aqua-Trol SWG
    Cartridge Filter
    Jun 2008
    Port Neches, Tx.
    144
    I've got a setup like yours.
    I ran at 50-55% during most of June and the beginning of July till I went on vacation.
    We had record heat at this time with almost no rain and was using about 5ppm of chlorine a day.
    Since the vacation it has been slightly cooler and cloudier with some rain and I've cut back to 35%.
    I try to watch it closely because if it drops down I'll get algea quickly.
    I've had and still have to vacume up the stuff your talking about, it varies alot for us because we have alot of trees. If we get algea the problem gets alot worse, I can vacume in the evening and in the morning there is alot of stuff laying down, by evening it looks bad.
    I've let the cl ppm drop to 3 and we get algea every time.
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    1 1/2 hp pump, sand filter
    Thanks. It has been very hot here the last few weeks also. (Southeast Virginia) So maybe I am worried about nothing.
    This is my first year with the SWG and I am still learning. Just couldn't figure out the sudden increase in %.
    I'll stick with the 60% and see how things go if we get a few overcast days.
    I was holding at 4.5 tonight.
    24' Above Ground
    Aqua-Trol SWG
    Cartridge Filter
