Thread: need new liner advice
    well i finally found our liner leak. the seam is splitting.
    the liner is only 4 years old so i think i have some warrenty left.
    besides getting the thiickest, it seems like that will be 25 gauge, does anyone have any advice on what they would do when replacing it?
    we did have a rock cut the bottom the 2nd year. and i have noticed the new coping strips are cracked, are there differrent brand?
    we will be having someone install it.
    27" overlap pool
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    Re: need new liner advice
    When you find your installer explain to them the problems you have had in the past with your liner(s).
    They should offer advice on what to do .... double check here if your not sure on the advice offered. Then choose the one you think is best suited to do the change out ....
    Good luck !
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
