Thread: Convert with solar cover on
    Can Opener's Avatar
    Aug 2009
    Vancouver, WA
    12
    Will CL at 15ppm damage the solar cover. What about the heater internals. I'm curious about doing the conversion with the solar cover on to keep CL in and debris out. I'd pour the bleach in front of the pump outlet into the pool to disperse. Any thoughts. What about the Bacqua goo going through the heater.
    Thanks.
    Above Ground 9,800 gallons
    Soft Swim but ready to convert to BBB
    Hayward Sand Filter
    Raypack 2100 187k BTU
    Solar Cover
    Re: Convert with solar cover on
    The high FC level will pose a risk to the solar cover. It shouldn't cause any problems for the heater, as long as the PH is in the proper range. Very little goo should get into the heater, it will be trapped in the filter before it can get to the heater. What small amount does get into the heater will be oxidized away in the latter stages of the conversion.
    Guest
    you want the pool uncovered to allow some gaseous by products of the conversion to gas off. Do NOT use the cover until the conversion is complete.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Plus, sunlight helps to break down the CCs that will form during the conversion process. leave it off.
