Thread: New pump install help
    May 2008
    Northern Virginia
    30
    My new SuperPump is enroute and should be here in a couple days.
    How hard is this to self-install? I'm not the most handy, but that's usually because I'm afraid of screwing something up and not because I actually do.
    It seems like all I need to do is shut off the breaker, cut the existing pipe, replace pipe and connect a few wires for the power. I'm probably simplifying things a bit. I've been having a heck of a time getting pool repair people to return calls let alone come out to check anything out.
    Is this too complicated? Any tips?
    Thanks
    _______
    35,000 IG vinyl with new Hayward Sand filter in 2006, chlorinator, Hayward 1.5HP Super Pump, Polaris with own pump, gas heater, 2 skimmers, 2 returns, no main drain.
    Aug 2009
    Miami, FL
    2
    Re: New pump install help
    I just did a self install of the same pump last week. It's not that difficult. As you stated, "shut off the breaker, cut the existing pipe, replace pipe and connect a few wires for the power." Just FYI the pump doesn't come with the wires already there so you will need to take the back cover off of the motor and connect them. Also you will need to find out if you are running 115v or 230v. There is a jumper inside there and you will have to select which one. Make sure when you replace the piping to use teflon tape on the threaded couplings, not pipe dope, and use PVC primer and cement on the other connections.
    12,500 Gallons
    Hayward C800 Cartridge Filter
    In Ground - Diamondbrite
    Hayward Superpump 1HP
    May 2008
    Northern Virginia
    30
    Gary,
    Thanks for the tips. How do you determine if I'm running 115v or 230v on the existing pump? By the threaded couplings, I assume you are referring to the threats on the pump itself and not the PVC.
    _______
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by GaryN69
    I have to disagree with that. Teflon tape doesn't work nearly as well on larger threads as pipe dope labelled for plastic pipe.
    Aug 2009
    Miami, FL
    2
    Well to determine the voltage I was running I opened up the back of my old pump. There was a diagram on it that showed it was wired for 230v, so that's how I set up the new one.
    For the threads I'm talking about the threaded couplings that will screw into the pump.
    The instruction manual that came with the pump said to use teflon tape and not pipe dope, but maybe JohnT knows something that I don't.
    12,500 Gallons
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    The reason some Manuf. tell us not to use the tape is because when you wrap the fitting with tape you are building up the fitting and actually making it bigger(this is if your using too much, too many wraps). Then when you screw it in, your'e expanding/stressing the female side more than designed and risk cracking the housing.
    Also, don't bottom out the fitting in the housing, can lead to a leak. I think they say hand tight and then 1/2, or 3/4, or 1, full turn depending on Manuf.
    Don't know why they would tell you not to use pipe dope. I use both actually, 2 to 3 wraps of tape then dope over that. call it over kill, but i haven't had a leaker due to thread sealant since. I hate having to do shiz over again.
    Factory Warranty Station for:
