Thread: New filter replacment for Jacuzzi ST-24 ?
    Cracked and leaking filter is Jacuzzi Model: ST-24
    Filtration Area: 3.5 Sq. Ft.
    Height: 27 1/4 In.
    Tank Dia.: 24 In.
    Media Lbs.: Silica Sand
    Sand Size: 48
    Sand Capacity 350 Lbs.
    Pool: In ground, vinyl liner, 18,500 Gals., Pool, filter, pump, all Approx. 10 yrs old.
    Bought house about 2 Yrs. ago and filter was already leaking. Filter tub is cracked & leaking badly. Found replacement Jacuzzi tub on net for $340. Problem is that some of the new filters, including the valves sell for less that the tub replacement w/o valves on this Jacuzzi. Thinking that I might as well buy new equipment.
    Can anyone recommend a replacement for my filter & valve ?
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    Re: New filter replacment for Jacuzzi ST-24 ?
    I would definitely replace the Jacuzzi filter with another brand as Jacuzzi went out of business a few years ago.
    Pretty much any 24" or 350lb sand filter will work. If you've got the space you could even go bigger. What size pump do you have, GPM?
    Something like the one in the pic on the right.
    Or this one.
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
