Results 1 to 15 of 15
Thread: cloudy pool
    cloudy pool
    Hi My pool has been cloudy since the first day we opened it. I have a 18ft round, above ground. 7600 gallons of water. I have tried all the expensive chemicals from the pool store and nothing works. Came to your sight and have been using bleach, borax, and baking soday for a couple of weeks now. the pool was a white cloudy, then after using the BBB, you could almost see the bottom of the pool, the other day I went out and vaccumed and brushed the sides and now it is a light green. I have a cartridge filter. what am I doing wrong? I clean the filter every other day. Help Please!!!! I love using BBB because it has saved me so much money.
    I have an 18ft round above ground pool with a hayward easy-clear micro filter, 1 hp pump, hayward automatic feed chlorinator.
    Re: cloudy pool
    Hi, Welcome to TFP!
    For us to be able to help you, you need to post your most recent set of numbers:
    FC
    CC
    pH
    TA
    CH
    CYA
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Re: cloudy pool
    sorry just had the wter tested yesterday.
    fac 5
    tac 5
    ph 7.6
    ta 180
    ch-225
    22,537
    Re: cloudy pool
    Welcome to the site. Glad you found it.
    Do you know your CYA #
    Have you done an overnight chlorine drop test?
    It sounds like you need to shock but the overnite test will tell more.
    If you don't have a good test kit you should consider getting one. Barring that at least the 6-way kit from Wally-World would suffice.
    Re: cloudy pool
    no they didn't do the cya test and I was using test strips but just ran out, I will be getting a better test kit. What is the overnight test you are talking about?
    Re: cloudy pool
    i just printed off the instructions for the overnight test. Thanks
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: cloudy pool
    as you see, you need a fas-dpd chlorine test to do the overnight loss test. I highly recommend the kit from www.tftestkits.net as it is the best value and has all the tests you need.
    Re: cloudy pool
    the pool place where we get the water tested told me to keep the solar cover on, I am going to leave it off the next couple of days. do you think that will help?
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: cloudy pool
    if you need to shock (and you do) then keep it off. don't listen to anything the pool store says starting now. get a good test kit and read the chemistry section in pool-school/ as well as pool-school/defeating_algae and pool-school/shocking_your_pool
    Re: cloudy pool
    ok I have to wait till payday to get a good test kit, in the mean time I have to shock the pool, how much bleach would that be? I started yesterday and added 3 gallons, left the solar cover off and have had the filter running all day and night so far, went out this morning and it is a lighter color, added 3 more gallons of bleach slowly, I am going to brush the sides and bottom and the ladder today. Thanks for the info so far.
    Re: cloudy pool
    We cannot know how much until we know the CYA level.
    http://www.troublefreepool.com/pool-...ya_chart_shock
    Testing at a pool store may or may not help, as some of them cannot do a test for above 5 or 10 ppm Free Chlorine.
    Re: cloudy pool
    my pool is no longer green its a milky color, you can see the third step of the ladder. Yeah. i am going to continue adding the bleach. I am so happy, You would not believe how frustrated I have been with these pool stores and How everyday you go in and they want you to buy this and that and all I needed was this website. I am forever greatful.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: cloudy pool
    Great Update.
    Can you provide some additional info....
    Go to User Control Panel, then Profile, then Edit Signature. Put in all the equipment/specs of your pool and pump/filter.
    Keep us posted.
    Re: cloudy pool
    pool is looking alot better, still a milky white but I know if I keep at it, it will get clearer. Thanks so much, I was about to tear down the pool because I was so frustrated. I was doing everything the pool place was telling me and spending so much money. I love this website, I am telling everyone about it.
    Re: cloudy pool
    My pool looks wonderful, wish I had found this website early in the summer. I will never go back to using pool store chemicals. Thanks pool school.
