Thread: Jandy AquaLink / AquaPure Problem
    Mar 2008
    Mansfield, Tx
    18
    I noticed the pool temp on my PDA was failing (said my temp was 125), then it would not display. Thought is was probably the sensor going out; then started having falling FC levels, so figured I've got a problem with the generator and/or tri-sensor. Turned off the power and cleaned the plates and sensor, still no chlorine. Ran the system in Service Mode and everything works great, displays pool temp, generates cholrine. The PDA won't even display the AquaPure option now, but still operates all other functions. Anyone got any suggestions? Unit is 15 mo's old and has run fine.
    16K Gunite, Spa w/ Waterfall
    Beadcrete Plaster. (3) Shear Decents
    Jandy 60 Sq ft DE Filter
    (2) Jandy Stealth 2.0 HP Pumps
    AquaPure SWG w/ PDA
    (5) Returns, (2) Floor Drains, (1) Skimmer
    LXi Heater, Letro Platium Cleaner w/ Booster Pump
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Re: Jandy AquaLink / AquaPure Problem
    You may have lost the com connection. Make sure that all your com cables are connected properly. I'm referring to the four pin connector that connects the PDA xmitter to the Jandy panel AND the same wire to the Aqua Pure. Some "pool guys" like to disconnect this so they can adjust the unit at the A/P box (outside). You don't have weekly service do you?
    Factory Warranty Station for:
    Mar 2008
    Mansfield, Tx
    18
    No Pool Service, I do all my own maintainance. I think it may be a ESD failure from a lightning strike from earlier this year. The system is 15 months old and should still be under waranty so I'm going to try to get a service company to come out.
    AquaPure SWG w/ PDA
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Good luck, and let us know what happened.
