Thread: Ranger gets stuck on the ladder. Any bright ideas?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    I have a Zodiac Ranger pool cleaner that keeps getting hung up on the ladder in my pool. So far the only way I can keep it from getting stuck is too shorten the hose, but then the clean won't reach all the way across the pool. I've tried making little barricades to keep it from going under the ladder but that hasn't worked either. Any ideas out there?
    Love TFP? Become a
    TFP Supporter!
    Re: Ranger gets stuck on the ladder. Any bright ideas?
    i take my ladder out of the pool when vacuum is running.
    24,000 gallon ig fiberglass pool
    1 hp hayward pump
    hayward sand filter (250 lb)
    madisonville, ky
    Jul 2009
    Houston, Texas
    9,396
    It's a pretty big ladder and is not going to come out easily, but thanks for the suggestion.
    Love TFP? Become a
    TFP Supporter!
    if you're talking about those big steps with the weight behind them that seem to allow the vac to go halfway in then stop - teh only thing you can do is to seal of the sides of the stairs straight down and back - it would require quite a bit of modification but is not impossible - I often thought abut putting privacy lattice down the sides - keeping it 1" away from the floor and wall, it's stiff enough that you can screw it into the sides of the stairs with stainless screws and washers and that should support the lattice fine, the lattice will allow flow through it.
