Thread: Question For Jandy Aqualink PDA Experts
    Jul 2009
    Long Island, NY
    267
    I have an Aqualink PDA-P8 control system which has one four-pin terminal block for RS485 communications. I presently have an ePump and the wireless transciever connected to the terminal block. The installation manual for the Aqualink PDA states that a multiplexer board has to be used if one needs to connect more than two wires to each terminal. I have researched the Jandy part number 6584 multiplexer board and it is quite expensive ($80+) and is nothing more than a small circuit board with four terminal blocks wired in parallel. Has anyone wired more than two RS485 devices without using the multiplexer board? If so, how did you do it?
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,694
    Re: Question For Jandy Aqualink PDA Experts
    Quote Originally Posted by poolneophyte
    Just cram them in there, Although i can't recommend you do that. I have seen sixteen wires in that buss before. four by four that is... It really is a shame that Jandy gouges like that.
    Factory Warranty Station for:
