Results 1 to 11 of 11
Thread: Aqua Rite with low speed pump?
    GregH's Avatar
    Aug 2009
    Dripping Springs, TX
    32
    I have an Aqua Rite salt system with a 2 speed pump, and it’s wired to come on only with the high speed pump. This seems counter-productive, defeating the cost savings of the low speed by having to run high speed to produce the FC. Is this right, or can I rewire it to run the salt system on low speed?
    20,0000 gal gunite IG pool, built May 2016. Jandy VS ePump, Jandy 60sfDE filter, AquaLink controller, PureLink salt water chlorinator, with Pentair Rainbow in-line chlorine feeder. Use a Taylor Total Poolcare DPD test kit. Heated by the Texas sun.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Aqua Rite with low speed pump?
    Quote Originally Posted by GregH
    You can try. The thing you need to verify is if the low speed moves enough water to trip the flow switch.
    Factory Warranty Station for:
    Yep, what Pool Clown said. The cell needs a certain minimum flow rate to work correctly. Most two speed pumps move enough water to keep the cell happy, but not all do. The SWG has a flow sensor that will turn it off if the flow rate is too low. As long as the flow sensor is detecting sufficient flow, you should be alright. Occasionally, they will only work on low speed when the filter is clean, and stop working as the filter gets dirty, but that is rare. Usually they either work or don't work.
    GregH's Avatar
    Aug 2009
    32
    Thanks. Rewired this morning, and all lights are green. Now it's time to experiment with how long to run it on low speed, but finding lots of help on TFP. Great site -- great find. Thanks!
    GregH
    I spoke to AquaRite since I own one of their "TurboCell" SWGs a few months back with the same question. They told me the AquaRite cells can work fine at a flow rate as low as 11 GPM which I guess is when the flow valve will trip. Just remember to adjust your percentage chlorine generation down a bit for longer filter times.
    I was initially told by a local pool store that SWGs don't work well with low-flow/variable speed pumps. But I decided to talk directly to the experts and they strongly disagreed with that philosophy. So don't always take advice from "pool stores" unless you can back it up with a valid source. Most of the folks on TFP know they stuff!
    Marc
    20,000 in-ground pebble-coat pool with 60sf Jandy DE filter, Pentair Variable-Flow pump, Goldline Aquarite SWG, Dolphin Premiere robot, passive solar heating.
    GregH's Avatar
    Aug 2009
    32
    Thanks everyone. By end of day yesterday I was down to 1 ppm FC so I ran my pump on low speed for 12 hours overnight at 100%, and tested this morning at 6ppm. Seems to have no problem generating FC on low speed! Changed my program to run a couple hours in the afternoon and 10 hours at night at 70%. I was using test strips before finding this forum a few days ago and all my numbers are off goal...though with the pool calculator and a better test kit I'm dialing things in closer already.
    Greg. Like I said, when you run your pool for longer periods, often times you can cut back on your chlorine generation. I find that if you keep your conditioner at the appropriate level (60-80 ppm) that you can keep adequate levels of FC with less than 50% on your chlorinator at low speeds. If you can generate enough FC at a reduced load, you can often times extend the life of your salt cell by not working it so hard.
    Glad you found us and hope we make servicing your pool a bit easier.
    GregH's Avatar
    Aug 2009
    32
    Thanks Marc! My CYA is one of the numbers that are off (in this case low at 42). From what you've said, and from what I've read in the pool school -- I'll back off the SWG % as I get my CYA up and my TA down to extend the life of the cell. I got my pH down to 7.2 this morning, and have been aerating it all day with bubblers and fountain. pH is up to 7.5 this afternoon, but TA is holding firm at 130 -- I'll have to re-read that part of the pool school and go another round on that battle tomorrow.
    But making progress, which is always good. Knowledge is the key to success. Luck happens, but rarely is sustained.
    GregH's Avatar
    Aug 2009
    32
    I’ve been running my SWG off the low speed pump since early August, and I thought I’d post an update for anyone interested. I’ve been running the low speed pump about 6 hours a night and have been able to turn down the SWG % output to 10-20% while easily maintaining FC in the 3-5 ppm range. I only run the HS pump about 2 hours a day to skim/vacuum the leaves in the pool. Water has been clean and clear, chemistry has stayed in balance per pool school recommendations.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Thanks for coming back and updating!
    So, what are your electric rates, and how much has doing this saved you per month?
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    GregH's Avatar
    Aug 2009
    32
    Good question, but I really don’t know how much I’m saving. Electric bill is high, but I have a family of 6 and all electric everything including heat pump and hot water heater. The pool is one year old last month, so I won’t have cost comparison data until this summer.
