Results 1 to 12 of 12
Thread: The skimmer weir thingy
    May 2009
    Ontario, Canada
    84
    I really don't like the skimmer door weir thingy.
    It's fine when the pool is empty but the minute we get any wave action going the thing gets stuck and then my pump runs dry so I either have to shut off the pump (which I don't want to do if there's actual sun to heat the panels and thus heat the pool) or I have to jam something in the door to keep it open.
    I'm constantly having to push it into the skimmer or push it out to stick the vaccuum....or the styrofoam keeps coming off......
    I'd be just as happy taking the door off.
    Any reason why I shouldn't?
    21' 54" Round AG, 10K gallons,1HP 2 speed pump, Sand filter 200lb
    Have had a sparkling BBB pool all summer....
    May 2009
    Dallas, TX
    782
    Re: The skimmer weir thingy
    The weir is essential for a properly functioning skimmer, so I would say no you shouldn't remove it. However, it does seem that yours is not functioning properly. Has it always operated like this? Can you see what it is getting stuck on? Is it physically damaged?
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    May 2009
    Ontario, Canada
    84
    it just seems to get jammed closed. It's a tight fit.
    22,542
    Ours was getting stuck once in a while and I finally figured out what was causing it. The piece of styrofoam was slightly moved to one side and was hanging on the edge of the throat. I pushed it back in place and have had no more problems. From your statement
    I'd suspect that might be causing you problems too. You can buy a new weir or just cut a new piece of styrofoam that fits better.
    I noticed that if I remove the weir the skimmer produces a whirlpool and sucks air into the pump.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    I had a lot of problems with my door and couldn't find a good replacement. I ended up getting a "floating" weir which is a thing that fits inside the skimmer basket and floats but is pulled down by the suction. it works pretty well. it's the one in the top left picture.
    http://www.lesliespool.com/browse/Home/ ... 40/I/34235
    May 2009
    Dallas, TX
    782
    Quote Originally Posted by aqualicious
    Has it always been such a tight fit? Is it the correct weir for the skimmer?
    If it is old and damaged, you should consider getting a new one. They are not expensive. Or you might try grinding the edges down a bit on your existing one, but if you take that route be careful. It needs to fit closely to work properly.
    May 2009
    Ontario, Canada
    84
    It's a new skimmer and it's always been tight.
    Should the weir freely go front and back?
    It only gets into this jammed problem when the kids are in the pool and making alot of waves.
    What is the point of the weir for exactly?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    The weir accelerates the water by minimizing the flow area as it flows into the skimmer and keeps floating debris in the skimmer when the pump shuts off. The easiest solution is a belt sander on the sides of the weir.
    May 2009
    Ontario, Canada
    84
    So Should the weir freely go front and back?
    SW Indiana
    9,198
    Yes. It floats up, and water flow pushes it down.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    It should not float forward to the point that it is inside the swimming area of the pool (laying down). It should be vertical when not in use and laying toward the skimmer basket when the pump is running. A little pool gasket lube on the top edges of the skimmer opening might prevent the weir from sticking.
    Love TFP? Become a
    TFP Supporter!
    May 2009
    Ontario, Canada
    84
    Ok, thanks everyone for the tips
