Thread: Weekend Trip Advice
    Weekend Trip Advice
    This is my first summer using BBB and I have a question regarding what to do when away from the house.
    This weekend I'll be away from the house for the first time since I started BBB and I'm just wondering what the normal process is when folks are away for a few days (3 for me in this case).
    Do I just bring my FC up to shock level before I leave?
    Do I leave my FC at normal level and just put the floater with some chlorine tabs in the pool while I'm gone?
    I assume I should leave my pump running the whole time I'm gone.
    Just looking for a little advice. Thanks in advance.
    18' round AG vinyl | avg. 3'9" deep | ~7,600 gallons
    Hayward Pro Series Sand Filter, Model S166T | Hayward 1hp Pump
    22,549
    Re: Weekend Trip Advice
    It really depends on your particular situation.
    Bringing it to shock level is good if you can cover it while you're gone.
    A floater will work if your CYA is on the lower side and your pH is on the higher side before you leave.
    You should leave the pump running if you don't have it on a timer.
    Three days is not a long time so with a little forethought it shouldn't be in too bad a shape when you get back.
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    I left for 7 days in early June, I brought my FC up to 18(my shock level), ran the pump for an hour & put the solar cover on, & turned off the pump.
    I came home 7 days later & turned on the pump at 9 pm, at 10 pm I checked the FC & it was 11.5, about 1ppm/day loss.
    Bob
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    Jan 2009
    Cupertino, CA
    1,966
    For just 3 days, shocking even without a cover would probably be okay. I use tabs but that's because I have a bucket full and need excuses to use them.
    --paulr
    BBB "Intermediate Swimmer"
    Thanks for the info.
    I do have a new solar cover, but haven't taken it out of the package yet and would rather not have to put it on just for a few days to be taken off again for a month.
    I think I'll shock it and put the floater tabs in there. Should be fine for the weekend.
