Thread: Losing Alot of FC Each Day - Is This Normal ??
    Jul 2009
    S. California
    157
    Hello Everybody:
    Thanks to the great advice already received from you nice folks here at TFP my new pool is clear and doing well. I do have one question though as I do not yet have the experience to know what is the norm. Now that my CYA level is stable and present I am finding that I lose an FC value of about 5-7 every day. My current target FC level is 4.
    The result is that each evening I use the pool calculator to overshoot my target level of 4 to about 7 or 8. By the next evening I am typically right at my minimum of 2.
    I did the overnight FC loss test about 1 week ago and was OK with a drop of 1FC and a CC of .5. I haven't tested the CC level since then, but have kept the FC level above 2. As mentioned, the pool is clear and looks good.
    My latest readings are:
    CYA 30
    FC 7 (this morning)
    PH 7.5
    TA 220
    TH 230
    Temp: 85
    For my pool size I need to add 10 ounces of 6% chlorine to raise the FC by a factor of 1. The result, adding about 50-70 ounces each night. This seems like alot. Maybe I am naive. What are your thoughts ??
    Thanks!
    Jim
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,089
    Re: Losing Alot of FC Each Day - Is This Normal ??
    I'd move the CYA up to 40ppm.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,965
    I agree, try a higher CYA level, you should be able to get to a 2-3 ppm loss with a CYA of 40-50.
    http://www.PerfectlyClearPoolService.com
    22,345
    I was losing 4 to 5 a day until I bumped my CYA up to 50. Now I'm losing 2 to 2.5 a day. I'm adding an average of 40oz of bleach a day.
    I agree with John & FPM. Bump your CYA up to 40 and see what happens. If that's not enough bump it on up to 50.
    Jul 2009
    S. California
    157
    OK will do. I'll pick up another 1# bag of Dichlor and dissolve it in over 2-3 nights.
    Thanks for your advice!
    Jim
    7100 gallons
    TF-100 test kit
