Thread: algae won't go away
    algae won't go away
    Hi there-
    I've been trying to rid our pool of algae for about a month now. I have a 33K vinyl liner in-ground and here are the latest readings:
    CYA=80
    CH= 50
    TA= 80
    pH=7.4
    FC= 12
    CC= 12.5
    I have been trying to keep the FC level at 15 to get rid of the algae. I've been brushing the pool daily, 2x a day if I can find the time. We are running the filter non-stop. When I shut the filter off, even for overnight once I think I have it cleared up, it seems to grow right on back.
    Any tips?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: algae won't go away
    With your high CYA, your shock level is 31ppm. Try that for a few days and you should get some results.
    Butterfly's Avatar
    South Carolina
    10,045
    Is CC 12.5 a typo? Did you mean TC? FC + CC = TC
    It would be helpful if you added your pool and equipment specs in your sig.
    Go to User Control Panel (upper left below TFP logo) & select Profile, then Edit Sig.
    Welcome to the forum
    You're done SLAMing when:
