Page 1 of 4 1234 LastLast
Results 1 to 20 of 61
Thread: Flow Switch for Goldline SWG
    Jul 2009
    Chandler, AZ
    3
    Hi all,
    I just stumbled across this forum and have been digesting this wealth of information. I have one quick tip that I thought I should pass along to add to the knowledge base here.
    My flow switch went bad earlier this year and I didn't want to pay the ridiculous price for the replacement. I thought about trying to build my own etc. Finally I was able to determine who manufactured the switch for Goldline. I was able to call them directly and order the part and they shipped it directly to my house.
    I believe the Goldline part number is: GLD-451-1001 or GLX-FLO-RP
    Here's the manufacturer info:
    Harwil Corporation (Oxnard, CA)
    PH Numbner = 805-988-6800
    Part Number = Q-12DS-C2 (Description = Goldline-2/No Tee)
    The folks at Harwil are very friendly and helpful. I paid $80 (including shipping) for my new switch. This is considerably less that I could find on the net.
    Hopefully I can help someone else save a few bucks by posting this on the forum.
    Thanks!
    15,000; IG PebbleTec; Goldline SWG; Swimclear Cartridge Filter
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Re: Flow Switch for Goldline SWG
    Thanks, Whollins, and welcome to TFP
    Will definitely keep this in mind for future reference.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Quote Originally Posted by whollins
    Hi all,
    Thanks!
    Thanks for the info. What was your SWG doing to determine the flow switch was bad. Mine the light comes on but does not flash like it use to for 60-90 seconds then it would start working. I was going to order a flow switch but was not sure and can not find a way to trouble shoot with certainty. Expensive trial and error Did you diagnose or just take a chance?
    Thanks
    Paul
    Costa Rica
    38'X26'
    1hp Sta-Rite
    300# Aquaworks filter
    Jul 2009
    Chandler, AZ
    3
    Paul,
    On the goldline setup that I have you get an error message on the controller display that says "no flow". Doesn't sound like you have the same setup? When I took the flow switch out it was obviously bad. It was missing the metal "flapper" that activates the switch.
    I've attached a picture of the flow switc from the internet for your reference.
    Hope that helps![attachment=0:1b3jzwuy]goldline flow switch.jpg[/attachment:1b3jzwuy]
    I get the no flow light on the control board but it use to flash now it burns steady. I took the FV out and there is no visible damage. I guess I will order a new FV and try it unless someone else has ideas. The $80 is much cheaper than the $1000 to replace.
    Thanks for your help.
    Paul
    Costa Rica
    38'X26'
    1hp Sta-Rite
    I cut the wires and bypassed the flow switch and my SWG started working again so I will order a flow sw. from the company whollins supplied.
    Paul
    Costa Rica
    38'X26'
    1hp Sta-Rite
    whollins you are a lifesaver! I had the identical problem with a flow switch today. The Goldline website is useless for troubleshooting so I googled the problem and came across your post. I found the little metal flapper stuck inside the salt cell when I cleaned it last month and could not figure out what the heck it was or how it washed into the cell. I don't know how the flow switch operated without the flapper for this long but it just gave me a no flow light today. Thank you for your post and thanks for the manufacturer contact info. I'll order one tomorrow.
    May 2009
    Rocket Town, AL
    49
    Nevermind...
    P.S. They are $68 dollars now, and the lady on the phone could not have been more friendly and helpful!
    Thanks TFP!
    18x36 In-ground Vinyl, 24,000 gallons.
    Sand Filter, 1hp Hayward.
    SWG
    Polaris 280
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,069
    Good job, I have made a copy for my files. This is good info. Thanks
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Thank you all so much - I just called Harwil, and exactly as described in the post - the lady that answered the phone knew almost immediately what I needed - very kind and helpful - $68 + shipping - like $80 compared to $200+ at pinch-a-penny.
    To test I needed a flow switch, I cut the end off an old phone cord and twisted all the wires together - I have the Hayward salt generator w/ the CO2 injection for pH balance (ORP).
    jd
    16'x34' IG Vinyl. 1.5HP Hayward 2spd. Hayward S244T sand. Nitro wall climber.
    Does the switch from the company in CA come with the cord attached like the picture above? I need to make sure I can replace it once it arrives if I order it. The local company here wants 159.95 + tax
    18 ft round (Intex style) Summer Escape pool
    1hp Hayward pump and sand filter (size escapes me)
    Intex SWG
    Planning an upgrade to a 24ft as soon as we wear this one out!
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Quote Originally Posted by PaulJohnston
    Paul
    what's the downside of leaving it like that for an extended period?
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    Ft Lauderdale, Florida
    1,455
    Worst case? Hydrogen gas explosion. What "CAN" happen is if you lose flow and the cell continues to be energized without flow, hydrogen gas will build up. When hydrogen gas collects in a large enough volume, and something ignites it, you will have pool parts all over the neighborhood.
    As long as you've got proper flow going through the cell to evaculate any gases, you're ok. Make sure your control panel is wired to turn off when the pump turns off.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    hmmmm - pool parts all over the neighborhood or expedite getting the flow switch? I'm gonna have to think about this one overnight. I keep thinking this is such a simple device, I should be able to build one or retrofit the old one.
    Brian
    Hey Whollins,
    I just called and ordered the replacement flow switch for my swg. The rep, Angela, could not have been more helpful and pleasant. She submitted my order and I expect it next Tuesday. I managed to save about $90 following your suggestion.
    Thanks for taking the time to share your information.
    28K IG Plaster, 1hp 2 spd motor on Sta-Rite 63 gpm pump, Pentaire 24" Sand Filter/ZeoSand. Dolphin robotic.
    Does the flow switch only monitor water flow and temperature or does it also determine the salt ppm? I'm having issues with the salt reading on the readout on my Aqua Rite T-Cell-15 not being accurate and was wondering if that was a flow switch function.
    22,000 gal, vinyl, inground, haywood filter, tiger shark cleaner (it's da bomb).
    Jason
    16x32 inground vinyl liner. 4ftx8.5ft?
    1HP Hayward superpump, hayward 300?lb sand filter.
    1 broken skimmer in middle, addition of dual inlet bottom drains in deep end
    3 returns (1 deep end, 1 shallow end, 1 center of shallow end.)
    cactusjake, no the salt measurement has nothing to do with the flow switch.
    I received my flow switch today and installed it in two minutes. I'm back online and saved $80 dollars plus $85 fee of having electrical pool guy come out to tell me it was the flow switch. Thanks all!
    Mar 2010
    Mobile, Alabama
    34
    For the record, count me among the folks who saved by ordering a switch from Harwil Corp. a month ago. Shipping was very prompt. Another thanks to whollins!
    16x32 IG vinyl liner, ~19K gallon, built with my own blood, sweat, & tears!
    1 hp Water Ace pump, Goldline Aqua-Rite 40K SWG
    300# Hayward sand filter, dual skimmers, pool open 12 mos/yr
  20. Back To Top    #20
    So...I just pulled mine out and it looks fine, too. How long was it 'til yours went bad??? Mine is almost 4 yrs. old, did that work for you? (Paul, Costa Rica, or others? Thanks)
    Chris
    Atlanta, GA
