Thread: Noisy pump, no pressure
    Phoenix, AZ
    Looking for advice on my pump/filter set up.
    Background: We had some work done on our pebble-tech finish last week, so we've been pulling rocks and fine gravel out of the pool. Also last week, the backwash was leaking so we had the o-rings there changed. That problem fixed. In addition to the gravel we've been dealing with, we're getting tons of small leaves from our neighbor's tree that keeps the skimmer basket full on a daily basis.
    Now, the pump is running very noisy and the pressure gauge on the sand filter is reading 0 when it was reading about 15 psi before. It does appear to be circulating though, I can see water and air bubbles coming out the returns in the pool. I have no idea where to start, but I'd like some ideas before I call the pool guy. :-p Is the pump broken? Why would the gauge read zero when it still appears to be moving water a bit? I don't know much about the pump, the previous owners left no documentation and I don't know how to figure out the hp or rate of the pump.
    Any ideas would be appreciated! Thanks very much.
    Newbie pool owner in Phoenix, AZ.
    12,000 gal inground pebble pool with a sand filter and a heater.
    X-PertPool's Avatar
    Exeter, PA
    Re: Noisy pump, no pressure
    It sounds like your pressure gauge is broken, this is very common. Replace the gauge, apply teflon tape to the threads and a thin layer of jacks lube or similar. Tighten to fingertight, not hand tight. Turn the system on if it leaks then turn it back off and tighten some more. in other words, don't wrench the pressure gauge in. This doesn't explain why the pump is runny noisey.. if it's just louder than normal than it sounds like it's trying to take a prime. If its a higher pitched squal it could be bearings. Regardless if the pump is pumping water the pressure gauge should be showing pressure unless it's broken.
    X-Pert Pool Service
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mar 2007
    Coastalish 'down easter'
    Welcome to TFP!!
    There is also the issue of air bubbles coming out of the returns, this is indicative of a suction side leak. You may want to check Pool School for the Leak detection article to see what might be going on
    Let us know what you find and we'll help (pics are always good )
    Luv& Luk
