Thread: Backfilling around pool
    Pool installed about a month ago. Getting ready to throw the extra dirt up against the pool and slope away.
    Probably 6 inches on ond side and 12 inches on the other. Do I need to put anything on the pool wall ( plastic, spray with anti-corrosion spray ) before doing this ? Once this is done going to put some egg rock on that.
    Above ground 33 ft round 52 in. high
    Approx. 25000 gallons
    Hayward Dreamline Sand filter holds 250lbs sand
    Hayward CL-200 chlorinator
    Hayward 1.5 hp 67 GPM pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Backfilling around pool
    you should check your local code requirements..in our town we need a 4ft high fence/barrier or 4ft high pool wall, while I theoretically could have backfilled 4 to 6 inches, we needed to keep that 4 ft height 3 ft away from the pool wall...so although I have a 24ft pool, the radius of level area the pool sits on is 30 ft..then the soil slopes upward. If you backfill more than 4-6 inches right up against the wall you lose the barrier the pool wall provides. Also check with you manufacturer to make sure backfilling would not void your pool wall warranty
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Quote Originally Posted by dmanb2b
    I backfilled no more than 4 inches...as per pool builders instructions. On top of that I put river rock and that comes out around a foot from the pool. Many people put pea gravel down and from what I have learned that only holds moisture next to and right under the pool. This is something you do not want...larger rock is what should be used.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
