Results 1 to 17 of 17
Thread: noob with cloudy water
    fordman's Avatar
    Jul 2009
    Iowa
    119
    Well first off noticed the other day water little green. tested with my wally kit no chlorine and ph low. Plugged the numbers into the clac. and added borax. Put in a gallon of bleach. Tried to vacuum bottom but went right back into pool through the intex filter. Then read need to bring pool up to shock chlorine levels. Don't know what that is so off to town and bought a shock and swim from wally put that in there and water got cloudy. Ph and chlorine way high. Let pump run all night then next day tried to vacuum again little better seems most staid in the filter. Now water still cloudy ph at 7.1 and chlorine between 6 with TA at 210. weather getting nice again would like to use pool so any ideas.
    1988 Ceder Ridge
    24' Doughboy AGP
    Re: noob with cloudy water
    You need to shock your pool WITH BLEACH or liquid chlorine according to your CYA level. See my signature for link to the CYA chlorine chart.
    Keep your pool at shock level until
    1) you lose <1ppm FC overnight
    2) your CC's are <0.5
    That will get rid of the cloudy and the green.
    Also, if you haven't yet, read Pool School, especially defeating algae and shocking your pool.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Keep in mind that an Intex filter can take weeks to clear up all the dead algae, and that is assuming it is all dead.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    fordman's Avatar
    Jul 2009
    Iowa
    119
    I don't know what my cya level is but I did add some when I put the pool up. Are the shock n swim ones any good or am I better off using 6% bleach?
    1988 Ceder Ridge
    24' Doughboy AGP
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    without test results it's a losing battle.
    pool-school/read_before_you_post
    fordman's Avatar
    Jul 2009
    Iowa
    119
    well our store closed and is doing some things from his house. Might have to take a water sample in to have checked for cya. but can check the chlorine and ph and ta at home. But we will see if they still do that and see what I got?
    1988 Ceder Ridge
    24' Doughboy AGP
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    you can but I would advise to get one now. especially with a bigger pool coming in your future, the test kit will be an indispensable tool and the experience and knowledge you gain now will help volumes, not to mention the help it will give you for your current pool and problem.
    fordman's Avatar
    Jul 2009
    Iowa
    119
    well with about a month left before we take it down am going to try and limp through. And will get a kit next year that way it isn't sitting around all winter.
    1988 Ceder Ridge
    24' Doughboy AGP
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    do you know how much cya you added?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by fordman
    Bleach.
    fordman's Avatar
    Jul 2009
    Iowa
    119
    I don't know for sure was 2 month ago but did put 6oz in the skimmer about 3 days ago.
    So will be buying more bleach since it is better than the shoke n swims.
    1988 Ceder Ridge
    24' Doughboy AGP
    fordman's Avatar
    Jul 2009
    Iowa
    119
    well added enough acid to lower ph to 7 pool looks clearer. Then turned the return jet up to areate the water to raise my ph back up and see how it goes.
    1988 Ceder Ridge
    24' Doughboy AGP
    fordman's Avatar
    Jul 2009
    Iowa
    119
    Well had water tested and only had 7 for cya so have the amount to raise in a stocking hanging in the pool. TA was 144 knew it was high working on getting it lower. Water looks lots better than when I first posted. Don't know if it is the filter finally cleaning the alge out or me working on the TA and PH. My guess is the filter.
    1988 Ceder Ridge
    24' Doughboy AGP
    fordman's Avatar
    Jul 2009
    Iowa
    119
    couple pictures of the water and new aerator.
    1988 Ceder Ridge
    24' Doughboy AGP
    nice!
    fordman's Avatar
    Jul 2009
    Iowa
    119
    Well got my TA down between 100 and 110. PH at 7.2 stopped areration because we got chance of rain tonight and see if it does and what it raises it to. Got the cya still hanging out by my return inlet. Water still not crystal clear but getting there. Might be little late in the season but I can use this knowledge on next years set up.
    1988 Ceder Ridge
    24' Doughboy AGP
