Thread: "Generating" light on SWG
    I have a Goldline SWG with a 25,000 gallon cell....Its currently set to about 30% (its new so i'm still tweaking it"
    Every time I open the box and look at it, the Generating light is on.......Does this light mean that it is actually making chlorine, or is it just showing that the unit is up and running?????
    It always seems to be on, or maybe I'm by chance looking at it at the wrong times....
    17,200 in ground Vinyl pool......
    Salt Water
    Sand Filter
    Jul 2008
    Solon, Iowa
    Re: "Generating" light on SWG
    Mine works the same way - that is, the light stays on regardless of the % you select.
    I think it is meant to stay on as long as no faults are registered, rather than turn on only when the generating voltage duty cycle is on.
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    thats kinda what I was thinking.....
    Salt Water
    Sand Filter
