Results 1 to 7 of 7
Thread: calcium chloride?
    May 2009
    Trenton NJ
    497
    calcium chloride?
    Is there a cheaper way to buy this stuff opposed to buying at pool store. I spent $35 for 15 lbs and I only needed 10 lbs. The salesmen said throw the rest on your driveway this winter.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: calcium chloride?
    pool-school/recommended_pool_chemicals
    CH - Calcium Hardness
    Calcium hardness can be raised with calcium chloride or calcium chloride dihydrate. Calcium chloride is available in some areas as PELADOW, DOWFLAKE, or DOWFLAKE Xtra, sold as a deicer by hardware stores and some big box stores. Pool stores will carry either calcium chloride or calcium chloride dihydrate under a variety of names, including Hardness Plus, Balance Pak 300, Calcium Hardness Increaser, etc. Calcium products should be spread across the surface of the deep end of the pool.
    30,419
    Sorry to be a busy body, but did you need it in that fiberglass pool?
    May 2009
    Trenton NJ
    497
    Yes my pool is fiberglass. It states in pool school for swg's to keep the ch at 250, mine was about 180 so I added some increaser.
    Aug 2007
    near the swamp
    806
    It can help aid in stain prevention, protect the gelcoat from corrosion in fiberglass pools.
    Guest
    Dave,
    Yes you do!
    It helps prevent cobalt spotting (only fiberglass gets that!) and helps with fiberglass's tendency to stain from iron.
    Guest
    I buy it by the 50 lb bag, it's cheapest that way. If you keep it sealed it lasts forever (not joking). I have gone through a bag in about 5 years now. My fill water from my water company is now 1/2 RO water so the CH is only about 200 ppm and I keep my pool at 300-350 ppm.
