Thread: PH testing question
    Jun 2008
    SE Michigan
    3
    PH testing question
    Hello, I have been second guessing my PH test lately, after 10-15 seconds my ph reads 7.4 but when i let it sit for a minute or so while i do another test it drifts up to 7.8-8.0. Could someone please confirm when to read the test or is something wrong? I am testing with a tf-100 kit. Thanks Scott
    fc-5.5
    cc-0
    ph-7.4?
    ta-120
    ch-30
    cya-30+
    18x34 ag, 14000 gal.
    18x34 Doughboy/13000 gal.approx./DE filter
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: PH testing question
    put the drops in, cap it, invert a few times and read it.
    Jan 2009
    Cupertino, CA
    1,966
    One of the chem/test gurus may have a detailed chemical-process answer, but for pH you read it right away.
    --paulr
    BBB "Intermediate Swimmer"
    Guest
    Add the reagent to the sample, cap , invert 3-4 times to mix (don't shake), and read. If you are going to do demand tests do them immediately after the pH test.
    pH can drift up on sitting, particularly if your TA is high.
    Jun 2008
    SE Michigan
    3
    Thank you, Scott
