Results 1 to 13 of 13
Thread: Dumb Bleach measurement question
    Huntsville, AL
    26
    Just curious how others are measuring your bleach. Whe the pool calculator says say I need 87 oz of Bleach is there a conversion I can weigh out there correct amount? Right now when it says add that much I try to just go with a half bottle of 182 oz bottle.
    YBnormal...have a pool
    15' x 30' Beachland AG Pool (12000 gal.)
    Hayward 1 HP Power-Flo LX Pump
    Hayward 18" Sand Filtration System
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Dumb Bleach measurement question
    I just guess with bleach - IMHO I don't think you need to be all that accurate when it comes to adding the chlorine, going a little over won't hurt. Others use a glass measure....
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by frustratedpoolmom
    No no no no no, NO glass near the pool. Plastic measuring cup.
    As waterbear likes to say, this ain't rocket science, you don't need super precision.
    --paulr
    BBB "Intermediate Swimmer"
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    22,553
    As said prior, it ain't that critical, however, If you're using the Pool Calculator when it gives you the result, pass your mouse over it and read the resulting Gal, Qts, Cups, Oz, measurement in the box that says "Mouse over a field for detail" out beside it.
    Jul 2009
    S. California
    157
    Just dump it in from a plastic measuring cup
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    I read on here somewhere last year with this advice: Get a two-quart plastic pitcher and mark the outside at the 1/2 quart intervals. This has worked well for me, especially since I add the bleach through the skimmer. I'll pour bleach to the first mark (1/2 qt), scoop up to fill the rest with pool water and pour it into the skimmer. But I don't use that much bleach - so my process is pretty quick. Others may need more bleach and may find this a bit cumbersome. While I prefer adding my bleach through the skimmer, I take the precaution of watering it down before adding it.
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    11,969
    Quote Originally Posted by PaulR
    Okay, I guess you're right if you are that clumsy you should use plastic.
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by Livinright
    In a small pool like yours, Livinright, "just dump it in" would probably work.
    With larger pools adding multiple cups up to significant fractions (or even entire) jugs, you want to pour slowly in front of a return jet (don't want bleach "puddling" on the bottom risking damage to the pool surface). I measure out a cup, then pour in a dollop (1/4-1/3 c.) wait a few sec for the jet to disperse it a bit, and repeat.
    Clumsy has nothing to do with it. You have an AGP with what, a wood deck? Can't remember.... nice soft surfaces anyway. Mine's plaster with tile and flagstone surround, I don't let any glass on there anywhere. Even a sturdy pyrex cup can chip and even the least clumsy can have a mishap. Sorry to have no sense of humor about this but I've stepped on glass one too many times.
    --paulr
    11,969
    Gotcha. Okay, sorry shouldn't have joked.
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    One of the best tidbits of wisdom I found here so far was the fact that one gallon of xx% bleach will raise your FC by xx (the same amount) per 10000 gallons. Since your pool is 20% larger than 10000 gal you'd see 20% less increase than I would, for example.
    For your pool, one gal of 5.25% bleach will raise the TC by ~4ppm (a handy amount, indeed) - guesstimate 1/4 gal for every 1ppm you need to go up.
    If you use Ultra, it's 6% and sold in smaller 48 oz bottles (about 1/3 gal roughly), so one would raise 10000 gal roughly 2 ppm. As was mentioned above, it doesn't have to be exact...
    Dan
    Edited the 1st line to make it clearer
    16' X 24' Wilkes Pools "Genesis", 10K Gal
    Hayward Powerflo Matrix 1 hp, & 18" Pro Series sand (S180T)
    Mar 2009
    eastern washington state
    275
    I am with pool mom!!! just get close does not have to be exact, your not building a bomb or something... i just dump from the container...
    good luck
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    Jun 2007
    New Jersey
    653
    I use five gallon carboys of 12%. For my pool, I took a DE scoop and marked it for 1 ppm (28oz. in my pool). I never use Pool Calculator for Cl now. Subtractions of numbers less than 10 I can handle in my head. I just pour in the number of scoops equal to the ppm rise I want. MA I just pour from the gallon. A dose is 1/3 bottle. Takes me from pH too high to just right. No Pool Calc there either. I'm a KISS guy.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
