Results 1 to 7 of 7
Thread: CYA Question: How Much is Too Much?
    WaterWoman's Avatar
    May 2008
    Sacramento, CA area
    139
    Hi guys!
    I have a question about CYA...
    My original thread about the pool is here: my-giant-pond-is-almost-a-real-pool-and-some-questions-t15311.html
    Initially (about a month ago), I added about 64 oz. of CYA (it's what I had on hand at the time). I put it in an old nylon and then put that inside a tube sock, and hung that in front of a return. It took more than a week for it to dissolve that way, about 10 days altogether. After doing that, and waiting a week to test the levels, my CYA tested at around 20 ppm. Last night, I finally added the rest of what was needed according to the pool calculator to get it up to around 40 ppm. However, I decided to skip the nylon stocking inside the tube sock, since most people said they just put it in a tube sock. Maybe I should've left the nylon stocking in there, too, because when I got up his morning, the tube sock was EMPTY. (I also think I may have inadvertently added a few ounces too much?) I really don't know what could have happened for it to have dissolved that quickly this time! I'm not seeing any undissolved substance in the pool, no clouds of anything anywhere. I turned the pump on high and put the vacuum in just in case, though, and have been running the vacuum for a couple of hours so far this afternoon. Everything seems to be working OK -- pump, skimmer, filter, etc.
    I decided to test the CYA just because... I know I'm supposed to wait a week, but this is unusual, and I'm concerned. I tested the pH and FC, too.
    FC: 5 (have been targeting for 5-6 range)
    pH: 7.2 (was 7.5 prior to this)
    CYA: 60
    OK, so that seems high on the CYA, above the target level which was 40-50. This IS a sunbelt region, and the pool gets a lot of sun every day, but is this going to be too much? I'm a little freaked out about this. Is this going to cause problems? What should I do???
    Thanks!
    20,000 gallon in-ground gunite ~ sand filter (62 gpm) w/Vari-Flo valve (75 gpm) ~ 1.0 HP dual-speed pump
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: CYA Question: How Much is Too Much?
    can you confirm how you tested the cya?
    what you do is follow the chart. mine is at 70.
    pool-school/chlorine_cya_chart_shock
    WaterWoman's Avatar
    May 2008
    Sacramento, CA area
    139
    Quote Originally Posted by reebok
    I used the CYA testing procedure in the Taylor test kit. Filled the little vial to 7 mL, added the CYA reagent to 14 mL, capped and mixed for 30 seconds, then slowly poured it into the CYA test tube until the black dot completely disappeared when held at waist level. That is the correct procedure, right? I got around 60 ppm when the dot disappeared. So, if it's at 60, I'm probably OK? Is there a chance it will go higher? I'm concerned that it all dissipated into the water so quickly.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    it shouldn't matter. it sounds like you did fine, just overshot somehow. of course there is a +/- 10ppm error in the cya test.
    I suppose it could go up higher, you can test again in a week and see. in the mean time I would follow the 60ppm level on the chart at minimum.
    WaterWoman's Avatar
    May 2008
    Sacramento, CA area
    139
    OK, thanks. So, I can stop panicking now?
    (I just can't figure out why it dissolved overnight like that. I was shocked!)
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Perhaps without the nylon stocking it allowed the water to pass more quickly through the more porous sock so it dissolved faster. I throw in mine the skimmer basket and it dissolves overnight as well .......
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    WaterWoman's Avatar
    May 2008
    Sacramento, CA area
    139
    Quote Originally Posted by TizMe
    That's probably it. I just wasn't expecting that, being a newbie and all! Thanks.
