Thread: pool light on and off then off
    I have had an on going problem with my shallow end light . its went off then on for a while then off perm. It was not the bulb . I brought in an electrician who rewired the light and it worked for a season . now its happening all over again. I am at a loss . Help !!
    22,548
    Re: pool light on and off then off
    Tell us a little more about your light. Make, model, voltage, anything you know about it.
    From the description it sounds like a transformer is heating up and shutting down.
    Aug 2008
    Conway SC
    102
    Unless its low voltage it wont have a transformer... Now could be the switch, breaker, loose connection?? I would change remove the switch and see if it stays on.. GFCI???
    17000 Gallons (16x32) Vinyl In Ground Pool
    Sand Filter
    Install "Finish Date" July 30 2014"
    Propane heater installed.. Used for 1 day.
    City Water.
    i have no idea about the make of the light . But where would the gfci or transformer or anything else be ?
    Aug 2009
    29
    Well its not the GFI if the pool was wired proplerly if it's kicked all the lights in the pool will be off.
    If the pool light in question can be turned on seperatly from the other lights in the pool it may be the low voltage relay that the equipment uses to turn on/off the high voltage. These relays are a moving part and offten fail. They "can" be taken apart and the connectors cleaned but generally once a relay starts sparking on its cycle it will fail again, and should be replaced.
    If the pool light is only controled with the other lights on/off and it has intermitant on/off its something singular to that light, either the light it's self, blub with a weak element etc. Most likely couperate is the junction box that splits off the lights from the power comming from the control box. This is generally a round black box with a square head (looks like a hat) these damp area junction boxs have to be mounted above the water line, and may be in a planter or other soil area around the pool. Find it, and make sure those connections in the box are proper.
    Hope this helps.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    If it is an american products (Pentair) light, Those have an internal heat switch that will turn the light off if it gets too hot. It may be malfunctioning. Or did you recently replace the bulb with perhaps a higher wattage? Or a globe type bulb?
    Factory Warranty Station for:
