Results 1 to 10 of 10
Thread: Shock after a Pool Party?
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    So we had a pool party for my 9 y/o son yesterday. I can almost guarantee many of the boys decided not to get out to go pee. I ran the filter overnight but can not decide whether to shock the pool or not. Thoughts?
    Yesterday's numbers:
    PH 7.8
    FC 7.0
    CC 0.0
    TC 7.0
    TA 90
    CH 80
    CYA 70
    Salt 3810
    Clint
    Pics of the build process
    34x16x25 Lagoon IG Vinyl 14,800gal (Oxford Tile/Glimmerglass 20mil)
    Pentair: Intelliflo VS3050 pump, Intellichlor IC40 SWG, Clean and Clear 320 cartridge filter, LA01N 3/4hp booster pump and Polaris 280 cleaner
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,374
    Re: Shock after a Pool Party?
    It won't hurt anything to shock it. If it makes you feel better, go for it!
    Love TFP? Become a
    TFP Supporter!
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    like zea3 says, if it makes you feel better, go for it. or if you want to let the chlorine already in there do its job and save money, then don't. you are below your target, so it wouldn't hurt to bump it up a couple ppm today since the sun will be on the water soon if it's not yet. and probably more swimmers too?
    Arizona
    924
    Yesterdays numbers don't do us much good. What are today's numbers? You only need to shock if your CC's are above .5
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    /breaks out of normal testing time
    (c:
    PH 7.8
    FC 6.0
    CC 0.5
    TC 6.5
    Looks like I should be fine
    Clint
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    heh, were those first numbers before or after the pool party? trying to trick us? :P
    I don't know how you usually do your pool care, but you're 1ppm away from minimum and the day just started. I would bump it up some myself.
    With a SWG, your current FC levels are just fine.
    For a major pool party you want to bring the FC level up higher than normal before the party. Then test the water shortly after the party and if it is bellow the minimum you want to bring it up well above normal. From what you have said about your numbers, you are just fine.
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    Thanks all.
    Jason, I shhould have thought to do that, thanks for the reminder for next time. I should have also told all those boys i use the purple dye too
    Clint
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    sorry about that, missed the swg.
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    Its ok reebok, i figured you had (c:
    Clint
