Results 1 to 7 of 7
Thread: SWG Users: What % is your unit set on this summer?
    Sep 2008
    The Woodlands, Texas, USA
    243
    I thought it would be curious to see what setting levels everyone is running their SWG at this summer. Please provide your data like this:
    Goldline T-15 cell - 24k gallons - 12 hr pump runtime - 87 F water temp - 50 CYA - 4.0 FC - 10% SWG setting.
    I thought this would be fun and interesting. The above is my pool.
    Lee
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: SWG Users: What % is your unit set on this summer?
    Auto Pilot SC-48, 21500 gals, 10hrs low speed 40gal/min, 85 deg., 70ppm CYA, 6.5 FC, PWR level 2 - 46%
    Have been getting alot of rain this summer.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    IC-40, 14,000 gal, 15 hr pump run, 83 deg, 40-50 ppm cya, 5-6.5 FC, 15-20% swg setting
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    Intex 8110. 24,000 gal. 9 hour pump run time, 82owater, 5 FC 80 CYA 50 Borate, 5 hour SWG run time
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
    Guest
    Goldline t-15, 6850 gal, 8 hour pump time, FC 4-5, CYA 80, output 8%, temp 88 deg+ (heater is set for 88 but the water is often warmer on it's own), borates 50 ppm
    Sep 2008
    243
    Bump
    Oct 2007
    Valrico, FL
    542
    Goldline T-15, 7500 gal, 9 hour pump run, fc 5, CYA 70, temp 90F, borates 40. I have attached a spreadsheet where you can calculate how much chlorine you are producing...
    Attached Files Attached Files
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
