Thread: polaris wall attachment
    my polaris will not stay plugged into the wall and it seems like something has broken off inside the wall so it will not lock in.
    is this something i can repair? I have a liner pool
    20 x 40 rectangle vinyl liner 33000 gal.
    Jan 2009
    Cupertino, CA
    Re: polaris wall attachment
    Most likely you can replace a part or two yourself. Check out this diagram for the 380; I'm pretty sure the wall fittings are the same for the other models. If you have a pool store nearby they can probably help you figure out which piece you need; my local guys were able to talk me through it over the phone, when I needed a new quick-release.
    BBB "Intermediate Swimmer"
