Results 1 to 19 of 19
Thread: Pool store says to use CLR for calcium buildup on tile?
    estogo's Avatar
    Jul 2009
    Houston
    34
    I went to my local pool store to get something to get rid of the calcium buildup I am developing on my tile. They suggested using CLR. I fi
    gure I could trust them because they didn't try to sell me something when they could have but wanted to get some advice from you guys. Thanks.
    15,000 gallon in ground plaster with hot tub. Chlorine Pool with Ozinator. 2 Skimmers
    SmartFilter 450/550 4 cartridge filter.
    2.5 HP Emmerson Main pump
    Hayward Super Pump II 3/4 HP pump for water feature.
    Hayward Tiger Shark robotic cleaner (LOVE IT!)
    3/4 Hayward Super Pump II 3/4 booster pump for Hayward Phantom cleaner (no longer used)
    30,424
    Re: Pool store says to use CLR for calcium buildup on tile?
    Not likely CLR will touch it. Muriatic acid mixed with water is the best. Start with a 5:1 ratio of water to acid. It'll probably take closer to 3:1 before it's strong enough to work. It'll foam up when you get it strong enough. If you haven't messed with it before, ask questions...it'll burn you.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Guess you still cant trust them can you ?
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    estogo's Avatar
    Jul 2009
    Houston
    34
    Nope, never used it other than pouring some in the deep end to balance chemistry. So, gloves? Sponge? (Don't like the calcium but like my fingers....)
    My buddy has some kind of spray stuff (hasn't gotten me the name yet) that he bought at a pool store. He uses a sponge/scrubber thing but no gloves so it probably isn't as powerful as the MA.
    Thanks for all of the help...
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    If you get the MA from the store and mix it yourself then you are sure of the strength.
    I would for sure wear gloves, sfety glasses - yep !. Sponge not sure on, stuff might eat it,.perhaps a rag? But someone who has used MA before (I havent needed to yet) should answer your questions shortly ....
    Les
    Helpful Links:
    Guest
    CLR contains both lactic acid and gluconic acid along with solvents and surfactants. Both of these acids can attack calcium ( lactic acid is what is responsible for tooth decay!) and can act as chelating agents. (CLT stands for Caclium, Lime, and Rust so the product is designed for scale and rust problems) However, I do not know if there would be any adverse effects on pool water so I would not recmmend its use in a pool.
    estogo's Avatar
    Jul 2009
    Houston
    34
    Quote Originally Posted by TizMe
    LOL - I agree. I did pout a little CLR on a buildup on top of my coping and it seemed to dissolve ok. I'll try the MA and see if that does better.
    I need to get a spray bottle or something because the worst parts are in the crevice where the tile meets the underside of the coping...
    30,424
    Estogo,
    The key for me when I handle muriatic is to always be prepared to immediately dilute it.
    So, it you spill a little on your jeans, immediately splash a big volume of water on it. You might save the jeans and you will surely save the burn.
    Same thing on your skin....if you get it on you, dip your hand (or whatever) in the pool.
    I have used it while in the pool. With goggles to protect your eyes, that's pretty safe 'cause you can submerge yourself if it gets on you.
    It eats any ferrous metal, most cloth, and many brushes. Plastic is almost universally immune.
    Always add the muriatic to the water....not the reverse.
    Stay upwind when pouring, if you get a whiff of it, you will not soon forget it. It won't harm you but it is an attention getter.
    Other than all the above, the stuff is harmless
    estogo's Avatar
    Jul 2009
    Houston
    34
    Estogo,
    Thanks for the great info...I've gotten a good whiff of it before when I was little and agree...unpleasant.
    What about some kind of plastic bristled brush to apply it with? Like some have said, I'm sure it would eat right through a sponge...
    Jan 2009
    Cupertino, CA
    1,966
    If I may be permitted a very slight digression... would diluted muriatic be reasonable for treating calcium buildup on fiberglass as well? I saw a question in another forum about dealing with calcium buildup in a spa.
    --paulr
    BBB "Intermediate Swimmer"
    30,424
    I have seen in either HD or Lowe's an acid brush" just like you describe.
    A fiberglass pool? I have no idea.....that's a good question. tho, and would be helpful to many to know the answer.
    Guest
    In a word, yes. Ditto for an acrylic spa.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Safety glasses.
    Gloves for chemical application (rubber or PVC gloves) - they're either green or purple, I forgot, sold at HD or Lowe's.
    An old toothbrush or a nail brush.
    I'd be careful about putting it in a spray bottle. You can get splash back into your face if you set the nozzle to 'stream'. If you set it to 'fine spray' you could easily inhale the droplets if you have any air movement and they drift. I would pour some of the diluted acid into a wide mouth plastic jar (mayonaise jar?) and dip the brush in it.
    Muriatic acid fumes paralyse the diaphragm. When it comers in contact with bleach it produces chlorine gas. In the dilutions we're dealing with here, i.e., a little bleach in a lot of pool water, you'll probably be ok but it might be a good idea to run a fan and blow the fumes away from the area where you're working.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    estogo's Avatar
    Jul 2009
    Houston
    34
    Hey guys,
    Wanted to let you know what I wound up doing. I got a plastic spray bottle and poured undiluted CLR in it. Did a great job of disolving the buildup in the tough to reach areas (where the bottom of the coping meets the top of the tile.
    So this beings up a question. What causes the buildup? It seems to be running in a few veins on my flagstone too.
    Pool is new (completed in Nov 08) and I wonder if that could havesomething to do with it?
    (none of my readings are "out of band" since switching to BBB)
    30,424
    I am very pleased (and surprised) to hear the CLR worked for you. It is certainly far easier (safer) than muriatic and I'll suggest it more frequently.
    What are your pH and CH results?
    I have used CLR and an attachment from home depot for my cordless drill its a soft steel brush. it took off the calcium better then the MA mixture.
    then i shined the tile with white vinegar. This was all on an empty pool
    18x36 - 25000 gallons - Sand Filter - IG Vinyl Pool with a Hayward 3/4 HP Pump
    Jun 2016
    Allentown/PA
    1
    Exclamation Re: Pool store says to use CLR for calcium buildup on tile?
    I just checked this on the CLR website. They say that you should never use CLR when Chlorine is present.
    Can I use CLR in my swimming pool?
    No. Mixing CLR with chlorine (or any other household chemical) is not safe and could result in toxic fumes.
    Can CLR be used on pool tile?
    Unfortunately, we do not recommend using CLR on pool tile. It could remove the finish from the tile. In addition, if CLR comes in contact with chlorine, it could result in toxic fumes.
    Taken from: http://www.thecarycompany.com/facili...eaners/clr/faq
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Quote Originally Posted by Rezolution View Post
    While this is an old thread and we generally refrain from bumping old threads you have added great information.
    Thanks!!
    Support the site
    May 2016
    PA
    16
    I've used a regular dish scrub sponge, while it didn't "eat right through" it showed that it was dissolving bits of the sponge..
    97 cents to put a little mechanical cleaning into the chemical reaction isn't a waste if you ask me. Just get good chem resistant gloves.
    16 x 30 Rectangular Concrete Pool
    Epoxy Painted
    Hayward S-180T Sand Filter, Marlow 1.3 HP pump
    Circupool Universal 40 SWG
