Thread: t-5 on 12000 gallon pool
    I am a new pool owner, i have a 12000 gallon pool with a t-5 cell, based on what i have been reading i should be using a t-15, the t-5 is fairly new and is working can i do anything like changing settings to make the t-5 work better
    Jul 2007
    Brisbane, Australia
    Re: t-5 on 12000 gallon pool
    if it keeps your FC level, you don't need to do anything
    if it's not keeping up - you can increase runtime/output percentage
    Sep 2008
    The Woodlands, Texas, USA
    The T-5 is just a smaller cell which doesn't last as many amp-hours of run time as a T-15.
    It still makes chlorine fine.
    Just crank it up till you get what you need out of it.
    Be sure to check the articles in Pool School for optimizing your water chemistry when using a SWG (i.e. keep CYA high enough) to maximize the life and output of the cell....they ain't cheap to replace
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
