Results 1 to 8 of 8
Thread: Solar cover and rain
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    This is the first time I put the solar cover on, we will be leaving for vaca tomorrow. I got it on and turned the pump on and it was spinning and everything looks ok.
    Will rain eventually flow into the pool with the cover on??? Will it just sit on top till it starts sinking the cover in??
    Dumb questions??
    18ft. Arcadia Round AGP - 19" Sand Filter, 1 hp pump
    Foam cove/ Gorilla Pad/ Wedding cake steps
    Sta Rite Lil' Shark cleaner and Aquabot Pool Rover cleaner - Aqua-Luminator light and return flow w/fountain attachment
    Added Borates 5/19/09 Taylor K-1005 and Taylor FAS-DPD Chlorine Tests
    May 2008
    Virginia Beach, VA
    84
    Re: Solar cover and rain
    The rain will run off in to the pool, no worries.
    28K IG Vinyl lined pool - 1 skimmer, 2 returns
    Hayward DE 60sqft filter; Polaris 280 vacuum with booster pump
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Thanks!
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    You may want to raise your FC level a little bit so you wont come home to a green pool if your going to be away awhile !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Yes I plan on shocking tonight.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Good, I didnt see it in your game plan. I was just reminding you
    Les
    Helpful Links:
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Thanks, it is ok to add chlorine with this cover on isn't it??
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Yep, Grab it so it stops spinning lift it a little and pour away !!! It may take 2 of you to do it depending on the size of your pool.....
    Les
    Helpful Links:
