Thread: Should I start the lowering TA process?
    skydiva44's Avatar
    Houston, Texas
    200
    Here are my numbers:
    PH - 7.8
    TA - 170
    CYA - 60
    FAS-DPD - 12
    Thanks!
    ABG Easy Set 18 x 48
    5455 gallons
    SWG
    Intex Pump 4000 GPM - Size B cartridge
    30,402
    Re: Should I start the lowering TA process?
    I would suggest simply adding enough muriatic to lower your pH to 7.2-7.4. That will reduce your TA as well.
    Then wait a few days and check pH and TA again...repeat in a few days.
    If your pH has not risen back up to 7.8 after a week, I would suggest to simply continue lowering pH as necessary and leave the TA alone.
    skydiva44's Avatar
    Houston, Texas
    200
    Thank you....I added the acid and already got it to 7.2!
    5455 gallons
    SWG
    30,402
    Very fast work! Cha-ching!
