Thread: Polaris Backup valve Cracked
    One of my polaris backup valve shell case is cracked and is almost gonna rip apart (the big round egg shape attached to the hose part # G52)
    I have two option replace shell case only? or replace the whole backup valve.
    Shell case cost around $23.00 and whole backup valve around $60.
    My question do i need to change whole new backup value or shell case.
    If shell case only is it easy to change the case? because black valve inside the casing is scaring me since i can't find any manuals how to replace the case.
    Can i use superglue or something to seal the crack will it work!!!
    sammm's Avatar
    North Richland Hills, TX
    Re: Polaris Backup valve Cracked
    Try some JB Weld on the cracked case.
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    Thanks for the suggestion, the plastic oring that keep the valve together was cracked. Just bought a new one and replaced it. had to buy the shell kit for $30 just to get the ring. polaris is good is screwing us lol.
