Thread: Do you use polyquat with BBB Method?
    doing a new pool startup after liner: The pool school says to add polyquat but BBB doesn't mention... should I use it? I had a huge algae problem last year
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Do you use polyquat with BBB Method?
    You can. I only use it at closing, since chlorine does a perfectly fine job of keeping algae away.
    30,432
    Case,
    Welcome to the forum. Many folks on the forum use it at closing. Others do not.
    During the season, we never recommend it.
    You had algae because your FC got too low. Adequate chlorine will jkeep your pool crystal clear.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    I have a bottle that I will probably use for closing, but the chlorine has worked just fine for me.
    I converted my pool to chlorine in May and have not even thought about using an algaecide. We have had nothing but rain here all summer, yet my pool has remained crystal clear.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
