Thread: Need advice on new motor H.P. (zapped by lightening!)
    geoshecks's Avatar
    May 2009
    Perry Hall Maryland North of Baltimore
    77
    Hi,
    Any advice on hp needed for 27' round 17500gal. filter is a hayward sand holding 200lbs. I replaced the pump before with a 1.5hp and I'm not sure if the pool originally came with a 1 or 1.5hp. Would a 1hp do the trick? (cheaper and uses less energy?)
    Thanks
    Geo
    Geoshecks
    Perry Hall, Maryland
    27' round above ground, 17100 gal, vinyl, Hayward1.5hp, 200lb.sand, EX baqua-goo user.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Need advice on new motor H.P. (zapped by lightening!)
    1 HP should be fine.
