Thread: 72 ft run to the equipment pad
    Is there much difference between running a 72 ft run to the pad compare to 56 ft?
    Just broke ground yesterday. We have to put our equipment pad on the other side of the house.
    The pool builder seem to be concerned with the longer run.
    the 56ft run will cut right in the middel of our existing concrete which I dont really like.
    the 72 ft run will be ran against the dividing wall.
    the longer run will let me run gas and water pipe to future bbq pad and I can just laid more grass on top.
    14000K gal 400sq ft w 6x8 spa, Pentair Intelliflo VS3050, Pentair cart filter, Pentair Master Temp, Pentair Intellichlor IC40, Pentair Easy Touch 8, wireless control. 3x intellibrite LED light. Pentair Kreepy Krauley Sand Shark. Solar Panel Plumbing. 2 x 24 inch arc sheer 24" spa spill way.
    Re: 72 ft run to the equipment pad
    72 ft is a long way to pump water from the pool to the filter. Thats why he's concerned.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    If it's straight pipe there's not going to be much of a difference. Using 2" PVC at 75 GPM the extra 16' will only add 1.4' TDH, or the equivalent of 2 extra 90's in the plumbing.
    30,414
    Yeah, as Tim said, it's no big deal. If PB was still concerned, suggest he run 1/2" larger pipe on those runs. Without doing the math, I bet that would actually decrease the tdh over the 56' run with 1/2" smaller pipe.
    Regardless, I would be comfortable adding the extra length, even if he doesn't increase the pipe size.
    Whats the elevation change between the pool and the pad?
    its a flat elevation run to the equip pad. other than the normal above ground level of the pump and below ground level of all the plumbing.
    I just told the grader to pull all the bush on the side of the wall regardless on which way PB will run the pipes. Cost me a little more to haul out the trees tho.
