Thread: i put in algaecide and now i have a bubble bath?
    Mar 2008
    Delaware
    40
    i used cheap hth walmart brand algaecide - it worked, killed the green algae.
    but now, anytime we jump or dive in, a bubble bath ensues.
    it's been 3 weeks and we're still bubbly.
    is there any way to get rid of the bubbles? can i use a foam reducer stuff for a hot tub in my pool?
    thanks in advance for the help.
    rjf
    Thank you in advance for your help.
    Noctiss
    30,415
    Re: i put in algaecide and now i have a bubble bath?
    Adequate chlorine in your pool will likely hasten clearing out the cheal algaecide.
    The pricier polyquat 60 algaecide doesn't foam but adequate chlorine is a better algae killer than either of them and won't give you the side effects you are experienceing.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Dave's right, chlorine kills algae, and maintaining proper levels of FC prevents it, making the use of algaecide unneccessary.
    Only in certain limited situations do we then even recommend the use of Polyquat 60.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    this forum is a great pool care resource and to learn all about the correct way to care for your pool so that you won't have any algae, won't have to buy algaecides, etc etc, start reading pool-school/
