Results 1 to 12 of 12
Thread: Overnight chlorine increase
    Oct 2007
    Asheville, NC
    43
    I'd been a bit slack in my testing and apparantly let me chlorine get a bit low. The pool clouded up some, and I assume it was an algae infestation that couldn't take entire control. I My CYA is around 40, so I used a shock level of 16. I have been doing the overnight test for about one week now. 7/25 pm FC 14.5, CC .5, 7/26 pm FC 15.0, CC .5. I figured that this was just a testing error, since I was within .5. 7/28 pm FC 10.5, CC 1.0, 7/29 FC 12.5, CC .5! Now I suppose the most reasonable thought is I somehow screwed up in testing last night. But is it possible for the chlorine to increase 2 hours overnight?
    How long from additiion of cholrine should you test? Last night I added chlorine and then went out. When I got back about 2 1/2 hours later, the timer had shut off (forgot to tell LLP(lovely life partner)) to keep the pool running. I tested shortly after turning the pump back on. Could it be possible that the chlorine hadn't circulated enough and gave a false reading?
    Johanna
    1984 vintage 16x32 Doughboy vinyl AG w/deep end, Sand Filter
    30,431
    Re: Overnight chlorine increase
    Johanna,
    The overnight FC loss test should be done only after your water is clear. Is it?
    Secondly, you are either not doing it correctly or not reporting the numbers correctly. Reread in Pool School how to do the test.
    I think if you can post a full set of test results and the appearance of your water, we can be of more help.
    If you have a SWG or tricglor tablet feeder, FC can increase overnight. Otherwise it is a testing error of some kind. You need to wait at least 30 minutes after a chemical addition, with the pump running, before testing. You also want the pump running for an hour before you take a sample to test with.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    I thought one of the nice things about having a fas-dpd test was the ability to stop shocking (thereby saving money) before the pool is clear by being able to identify when the algae is all dead. I am basing this off a few things, including this article and thread:
    pool-school/shocking_your_pool
    how-to-shock-article-update-suggestion-t14672.html
    Quote Originally Posted by reebok
    That is what I believe, but not everyone agrees with me about it. Essentially, you can stop if you know what you are doing and are doing the test correctly, etc. But some people use that statement as a license to stop shocking after an OTO test still reads high the next morning, which doesn't work.
    30,431
    What I see on the forum frequently is,
    "My FC held overnite and my CC's are .5.....Why is my pool still cloudy"
    The answer invariably is that the tests were not performed properly. However, rather than review the techniques and how pertinent it is to do the overnite test with FAS/DPD only, I like to add the criteria of clear water as well.
    That pretty much eliminates the other errors that can and do happen to newbies and it is what they were all trying to accomplish anyway.
    The chlorine savings would generally be small (but notable) compared to being able to swim a little sooner or possibly even continuing to fight algae in a "break even" pattern for several more days.
    Oct 2007
    Asheville, NC
    43
    I appreciate all of the replies. My water is clear. I've been using this method since last year, and think I know how to do the chlorine test. I am using bleach, so there is no additional chlorine added overnight. I just got home this evening and haven't done a full test tonight. But last time I tested anything other than PH and chlorine, my TA was 110 and CYA 40. My Ph has been about 7.5 (I never feel real comfortable with those color matching tests). Maybe I was just tired last night, it was pretty late when I was able to test the water!
    Johanna
    30,431
    The test I am referring to is the Overnite FC Loss Test.
    That test requires a result in the evening and then another test and result the next
    AM. The post for an Overnite FC Loss Test should look something like this example.
    7/26 -7:30PM FC-16.5 ......7/27 6:00AM -FC-16.0
    In your post, you only report PM testing and that's what is confusing me.
    Arizona
    924
    The drop sizes may have been different and would cause your test results to be slightly different.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Oct 2007
    Asheville, NC
    43
    OOPS! That should have been -- 7/25 pm FC 14.5, CC .5, 7/26 AM FC 15.0, CC .5. and 7/28 pm FC 10.5, CC 1.0, 7/29 AM FC 12.5, CC .5!
    Clearly this is a testing error on my part because last night I tested the chlorine twice, withing about 15 minutes and came out FC 11.5, CC 1.0 and FC 12.5, CC 1.0. This morning it was FC 11.5, CC.5. I suppose I shall have to work at being more consistent with my drops! It was always my understanding that the bottles were designed so that the drops would be consistent.
    Johanna
    For uniform drop size, you want to hold the dropper bottle vertically, squeze gently so the drop falls off the tip when it gets heavy enough instead of "spraying" out, and wipe the dropper tip once in a while with a damp tissue.
    Oct 2007
    Asheville, NC
    43
    Thanks for the tips on consistent drops! I will try that out tonight. The good thing is that my pool looks gorgeous again. so hopefully what I have been doing is working, even if my readings aren't! I will continue with the overnight drop test again tonight and see how I come out.
    Thanks again,
    Johanna
