Thread: power consumption and output questions
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    I'm trying to use the calculator here: http://www.tdconsulting.com.au/bleach1.php but am having a hard time figuring out the power consumption and chlorine output numbers. I am mainly looking at the hayward swimpure (manual here: http://www.haywardnet.com/products/Manu ... ual261.pdf ) but I will take numbers for any swg that anyone feels like posting. thanks.
    p.s. I have read the thread that the calculator came out of, and a few others like it ;)
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: power consumption and output questions
    This is ball park but my unit uses about 200 watts to generate chlorine. The spec is 1.45 lbs / day of chlorine which would require 4800 watt-hours to generate. So that is about 0.3 lbs/kwh. I am in tier three so I pay about $0.35/kwh so that is $1.17 per pound of chlorine. There is about a half pound of chlorine in a gallon of 6% bleach so I would say bleach is probably more expensive but that is only for production. It doesn't take into account the initial cost of the unit.
    Mark
    Jul 2007
    Brisbane, Australia
    874
    1.45lbs/day = 27.4g/hour
    Manual doesn't list power consumption but 200W sounds about right, so you'd enter 0.2 as your power consumption.
