Thread: Testing ph using the TF100
    Jul 2009
    Norman, OK
    16
    I'm one of those individuals who has difficulty with some of the color comparison tests. With the ph test, I can't tell one color from the other with direct (or front) lighting. However, if I hold the test up a light source with a consistent background, then I'm better able to make the comparisons. Specifically, I've started holding the test up to my skylight with a blue sky in the background.
    Does this technique impair the precision or accuracy of the test in any way?
    Thank you in advance for the input!
    My details: 16x32+swimout, 14,300 gallon, gunite/plaster pool, Jandy CL460 cart filter, 1.5 hp Stealth Pump, QuikClean six zone in-floor cleaning system, QuikPure QP3-25 Ozonator
    Re: Testing ph using the TF100
    The PH test is actually destned to be held up to a Northern blue sky.
